Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 11-04-2004, 12:46 PM
benevolance benevolance is offline
Possible head Gasket?
Hello,
Just bought a 1987 civic 4 door sedan (automatic) It only has 83,000 miles on it...And it is rust free and clean (south carolina)..I bought the car cheap...But I cannot get it running. The previous owner said that they took it to a shop and they indicated that the head gasket was bad.
This does not exactly scare me as I have changed dozens of head gaskets for friends and such... But I was troubled that I could not quite get the car to run. A bad head gasket should still allow the car to run, even if it puffs white smoke and idles like a bag of crap.
Any ideas?
-benevolance
Old 11-04-2004, 07:07 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: Possible head Gasket?
You're right, even with a bad head gasket your car should start. How long has it been sitting? Are you getting gas and spark?
Old 11-05-2004, 09:16 AM
Re: Re: Possible head Gasket?
There is fire...And gas.
The car was supposed to be sitting only a month but I suspect that it was more like a year. I am going to get some quick start and give the carb a spray of that.
the battery is so dead it will barely turn over even with a boost. I may have to buy a battery just the get the car to turn over fast enough to start.
-Benevolance
Old 11-05-2004, 12:59 PM
lxndr's Avatar
AF -Advisor
That's exactly what I would have recommended next.
Old 11-06-2004, 02:57 PM
Even with a new battery it has trouble starting. I did a compression test and it is a bit low...I am thinking that it is either a case of stuck valves or a bad head gasket.
I wonder if the head gasket being bad alone would drop the compression enough for me to notice it?
-benevolance
Old 11-06-2004, 08:57 PM
lxndr's Avatar
AF -Advisor
Hmmm...
I'd try fiddlin' with the carb next.
Could be that your needle valve is stuck in the closed position. This sometimes happens when cars sit for a long time and the gas evaporates from the carb.
Old 11-21-2004, 07:32 AM
revhalzoo revhalzoo is offline
its probobly waterlocked, you wont get it to turn over. pull a plug and check for water if there is, open the head replace the gasket and evacuate the water from the cylanders
