Old 11-04-2004, 01:16 PM
bighead bighead is offline
White smoke
Okay... I just replaced the head gasket in my 97 Cav, 2.2L . When I went to start it, it started but, I had a lot of white smoke coming out of the exhaust. It looked like a mosquito defogger going through the neighborhood.
I torqued the heads down to 43lbs on the short bolts and 46lbs on the long bolts.
Any ideas?
Old 11-04-2004, 01:33 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: White smoke
sounds like when people sea foam their cars.... lol...
Should be just burning off the excess oil... but if it continues then... did you clean the old gasket off well?... and when you installed it... when you tighten the bolts did you work from the center out?
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 11-04-2004, 01:36 PM
Re: White smoke
okay... how long should it last?
I followed the Chiltons guide....1-2-3-4-5-6-7-8-9-10
thanks again
Old 11-04-2004, 03:08 PM
Re: White smoke
going from bad to worse....
the white smoke stopped.....but now i have water/anti-freeze leaking out of the corner of the engine block. I had the heads checked and shaved when it was off. I torqued the head bolts to the correct settings...
any other ideas?
Old 11-04-2004, 03:18 PM
Re: White smoke
oh yeah.... it started making a noise as if it were struggling to keep going. When i tried to restart the engine..it wouldn't. So, I am in the process of taking it apart to see WTF went wrong...this sucks.....
Old 11-04-2004, 04:14 PM
Re: White smoke
Another twist to the plot...The guy who owned the car before me had a problem of overheatiing...I think he mixed the Dex-cool and regular anti-freeze. Could it be possible one of the radiator ports inside the enginge block is clogged?
Old 11-04-2004, 06:14 PM
public's Avatar
public public is offline
Re: White smoke
White smoke is not excess oil. It is coolant. Oil=blue smoke.
Coolant, Tranny fluid, and brake fluid=white smoke.
The torque spec you give in incomplete. Torque the the required foot pounds PLUS 90 DEGREES. You will have to redo this head gasket. Most head bolts end up over 80 lbs of torque so you are way shy. You mentioned that you shaved the head so you should be fine just putting in a new head gasket. Good Luck.
Yes, I am retarded.
Old 11-04-2004, 06:48 PM
Re: White smoke
yeah... i did the 43LBS and 46LBS respectfully, plus 90 degrees. ieven called the local Chevy Dealer... the tech agreed with the rates I mentioned.
It could be that the torque wrench was out of calibration.
I'm thinking 10 hours of labor and a new head gasket I will be fine. Since the bolts probably weren't torqued down all the way, and were not stretched, I won't buy new ones.
This is annoying as hell....But, oh so fun....
Old 11-04-2004, 08:23 PM
public's Avatar
Re: White smoke
The head gasket on this car is only about 4 hours. You will be supprised how much faster you are the second time.
Hint: Leave the intake manifold on the head. Again, Good Luck.
Yes, I am retarded.
Old 11-04-2004, 10:09 PM
Fireplug Fireplug is offline
Re: White smoke
NEVER REUSE tork headbolts
never never never
If you did the 90 deg then the bolts are junk
1 . make sure the block and head are clean and dry
2. The tork pattern should start in the center of the head and work its way out in a round pattern
Old 11-04-2004, 10:14 PM
Re: White smoke
but... the bolts were not torqed correctly...I'm reusing them...at $8.00 each... they are like gold...
Old 11-04-2004, 10:28 PM
Re: White smoke
You said
yeah... i did the 43LBS and 46LBS respectfully, plus 90 degrees. ieven called the local Chevy Dealer... the tech agreed with the rates I mentioned. so did you tork them +90 or not??? If you did and reuse them it will not last long
Old 11-04-2004, 11:10 PM
i also stated the torque wrench could have been wrong.....
Old 11-05-2004, 04:22 AM
Re: White smoke
okay... this time i will use a gasket sealant on both the engine block and the heads. A complete "sandwich" of gasket sealant.
Any views on the stuff?
Old 11-05-2004, 05:43 PM
public's Avatar
Re: White smoke
I have reused head bolts for years even on this model and have never had an issue. I know their stretched, 80% of yield strength, etc... If I had bothered to read the manual I would have been scared and replaced them. But I didn't.
Hell a couple of times through the years (roadside repairs) I didn't even use a torque wrench, after 20 years you just learn how 80 ft/lbs feels. Haven't had to redo one yet. Hope my luck holds.
But anyways, never use gasket sealer on a head gasket if you did that is the problem. This is a mated surface. Good Luck.
Yes, I am retarded.
