Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-04-2004, 10:46 AM
blownonfuel blownonfuel is offline
2001 Chevy Sub. Hesitates, Need info. on scan tools.
Hello To All, I'm starting to have problems with my wife's sub.. Can anyone recommend an obd II scanner that I can check the codes with? Not looking for anything fancy just something that I can get started with. The sub. has an intermmitent hesitations and sometimes also smokes (black) on startup. Just started about a week ago. No check engine light.
Thanks
Old 11-05-2004, 08:55 AM
praisethelowered's Avatar
praisethelowered praisethelowered is offline
Re: 2001 Chevy Sub. Hesitates, Need info. on scan tools.
Most auto parts stores have a scanner on hand to check codes, but if you're planning to purchase, JC Whitney has several moderately priced units.
Old 11-05-2004, 10:32 AM
Jeremy-WI Jeremy-WI is offline
Before buying some fancy scantool, it sounds like you are having a fuel pressure regulator problem. I imagine you have a 5.3 or 6.0L motor. Find the pressure regulator and pull the vacuum hose off(with engine off), if there is fuel in the vacuum line replace the regulator
