Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 11-04-2004, 06:07 AM
ryanbailor ryanbailor is offline
Accidentally ran out of gas, and now wont start after refill?
I was on the freeway, and it felt like I was running out of gas... I got off, and luckily made it to the gas station. I filled up, and she started right up like normal, but i pushed on the gas pedal and it stalled. this kept happening for abut 5 minutes until it decided to not start up at all anymore... Can anyone help me, it's my only mode of transportation right now.
Old 11-04-2004, 01:31 PM
izzybay74 izzybay74 is offline
86 golf (not gti) Same thing happened to me.
I pulled into the grocery store, needle was on empty, and it started sounding like it was out of gas, then when I put gas in it wouldnt start! Could it be the fuel pump?
Old 11-04-2004, 03:15 PM
boschmann boschmann is offline
Re: Accidentally ran out of gas, and now wont start after refill?
'86 Golf? Can you hear the main pump (by the right rear wheel) run for a couple of seconds when you turn the key to on position? If not suspect it's died. If it hums there is also a transfer pump in the tank that would need to be checked.
Old 11-04-2004, 08:26 PM
edspecR edspecR is offline
Send a message via AIM to edspecR
this is why i never run on empty. running on empty exposes the internal fuel tank fuel pump, which can cause damage. maybe this is what happened to you.
take it as a good lesson in taking care of your car... or treating it nicely
Old 11-07-2004, 03:02 PM
Re: Re: Accidentally ran out of gas, and now wont start after refill?
Hey thanks, I cant hear a thing when i turn the key on, so I'm changing out the external fuel pump. Can you help me with some breif basic instructions? Or tell me anything I should know NOT to do?
Old 11-09-2004, 07:17 AM
Try this first. Locate the fuel pump relay, it is on the main relay panel, upper row, last on the right. When you pull it out you will notice two larger pins that are perpendicular to each other. Get a jumper wire or paper clip & connect these pins on the relay panel (key on). If the fuel pumps run then it may only be the relay.
Old 11-10-2004, 01:59 PM
Okay I tried it and it's not the relay. Should I just do the fuel pump now?
Old 11-10-2004, 02:32 PM
If you jumpered those two pins & the pumps didn't run (& you checked the FP fuse, #10 I beleive) then it's back to the main pump first. You should check for power there before replacing. When the key is turned to on position there should be 12V for a couple of seconds.
Old 11-28-2004, 06:26 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Usually the transfer pump in the tank will fail before the main pump.
