Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-04-2004, 01:53 AM
99SpoonCivic 99SpoonCivic is offline
Question Type-R Turbo
I currently have a 99' Civic Si and wanted to upgrade the b-16. While looking for internals for my block i came across a stock b-16 Type-R block with 0 miles. So now i have a Type-R block and i really want to put a mild turbo setup on it with anywhere for 7-9 psi. I just havent found anyone to ask if this is possible with the compression of the type R. I don't know if i sould go N/A or turbo. If anyway possible i would like to go with the turbo. Just want a everyday driver with turbo but dont want to sell or scrap my type-R block. Any hints or suggestions are much needed.
Old 11-04-2004, 02:07 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Type-R Turbo
I'm sure it can handle 7 psi, but I wouldn't chance it. Replace the internals with forged parts.
Empty Pockets Racing Member #1
Old 11-04-2004, 08:12 AM
ridestreet84's Avatar
ridestreet84 ridestreet84 is offline
Send a message via MSN to ridestreet84
is it a bare block or is it a block with internals if its a bare block it would be able to handle it you would just have to use lower compression pistons
Goodbye civic Hello turbo outback goodbye outback Hello WRX
Old 11-04-2004, 11:02 AM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
Re: Type-R Turbo
it can handle 7psi on stock internals I have a buddy that has a SC on his Si and has been running 8psi for a year and a half now with no problems.
Old 11-04-2004, 03:03 PM
b18ls's Avatar
b18ls b18ls is offline
Banned
Re: Type-R Turbo
If you change out your CTR pistons, let me know, I'll take them off your hands.
Old 11-04-2004, 05:24 PM
the block already has type R pistons, rods, and crank. It is ready to be dropped into the car. I just really don't want to put new pistons in it if I can get away with it.
Old 11-05-2004, 11:06 AM
b18ls's Avatar
Banned
Re: Type-R Turbo
The CTR pistons yeild a high comp ratio. You don't want this if your going Turbo. If you decide to go all motor, than you should keep the pistons. If not, you might want to change them.
Some one please correct me if I'm wrong. I don't want him to think I'm lieing to get his pistons.
Old 11-05-2004, 11:24 AM
Re: Re: Type-R Turbo
you're right about the high compresion ratio on the type-r pistons but you can safely do F/I on high compression pistons, just with not as much boost.
For example: the power would be about the same if you had the high comp. type-r pistons with 7psi or lower comp. pistons with 12psi.
but if you want to run more boost either build up the internals or lower comp.
Old 11-05-2004, 06:22 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Type-R Turbo
Man did you buy the wrong block for boost! I'd say 6-7psi might be okay, but if you're going to fork over thousands of dollars for a turbo kit just to see like 50hp (with those pistons, unless you feel like breaking parts), that's just stupid. I'd say swap them out for some 9:1 or 9.5:1 pistons so boost can be your friend, and a V8's enemy
Old 11-05-2004, 08:20 PM
b18ls's Avatar
Banned
Re: Type-R Turbo
With all that said, would you like to get rid of your pistons?
Old 11-06-2004, 03:00 AM
Naw, I am going to hang on to the pistons. I a mjust going to go all motor and a shot of nitrous.
Old 11-06-2004, 11:40 AM
Ricochet's Avatar
Banned
Re: Type-R Turbo
You may want some different pistons for that too.. and rods. The ctr's are cast iron, which is too soft for the big bang nitrous makes. Say goodbye to your rings too, as the n2o will slowly melt them away. With the setup you now have, it's expensive, but your only feasible option is to go all motor.
Start with an Si short ram intake, 4-1 header with a 2.5" collector, a high-flow catalytic converter, and a 2.5" (apexi world sport) exhaust. If the money's right, get some yummy Toda B cams to wake her up in vtec and you'll have a quick, reliable ride. If you don't want the old parts you can always sell them for a nice chunk of change on here or other forums (i.e. www.honda-tech.com ).
Old 11-06-2004, 01:33 PM
b18ls's Avatar
Banned
Old 11-06-2004, 04:12 PM
Re: Type-R Turbo
i say sleeve it and get some forged parts and still go boost! (and consider selling your pistons to b18ls cuz i can tell he really wants them)
Old 11-06-2004, 08:47 PM
blkciv98EXwithopes blkciv98EXwithopes is offline
Re: Type-R Turbo
i have the stock vtech ex motor (d16y8)... and its ok with 7 psi boost, no new internals? If so, whats the best way to upgrade a turbo?
