Go Back   Automotive Forums Car Chat > Ford > Excursion
Old 11-04-2004, 12:14 AM
wowchad wowchad is offline
2nd row switch - bench to quad seats
I'm having a hard time finding a used Excursion around here with the second row quad seat option.
If I bought a pair of seats would all the mounting be the same?
I like the way quad is set up like my old conversion van, but have come to terms, if I really want that I'm going to have to do it after the sale myself!
Old 11-29-2004, 08:21 AM
Re: 2nd row switch - bench to quad seats
I've found out that the rear quads cannot be swapped, the mounting is very different from the bench seat.
Old 11-22-2008, 02:47 PM
spliff911 spliff911 is offline
I have a 2000 Ford Excursion and I started it the anti theft light came on and it wasn't working very well when I got home I turned the truck off and now it won't start. What should I do?
Old 11-22-2008, 02:49 PM
How do I get my 2000 Ford Excursion to start the theft light came on while I was driving it as soon as I shut it off it won't restart. What should I do I have tried the key code on the door to unlock and opening the truck with the key. I'm not sure were to start. Please Help
Old 11-25-2008, 03:06 AM
Davescort97 Davescort97 is offline
Escort guy
If you disconnect the positive battery terminal for 5 minutes and then put it back on it may reset the computer on the RAP (Random Access personality) module. Check all your fuses under the hood and in the passenger compartment.
Old 12-10-2008, 08:54 PM
rhandwor rhandwor is offline
Use a noid light and check for power to the injectors the link is a picture.
http://www.autopart.com/tools/toolsmain/tool/T_3411.htm The security system normally cuts power to the injectors. In case this call a locksmith who does this or get towed to a dealer. Normally another key will start the car try a spare key if you have one.
