Old 11-03-2004, 10:33 PM
soulreaver soulreaver is offline
Send a message via AIM to soulreaver Send a message via MSN to soulreaver
your input
thinking about this car
I'm asking $2,000.00. The first one to bring me the cash takes it!
-The cars has over $2000.00 worth of mods in it now!
1993 Eagle Talon TSi AWD
Mods:
(Intake)
-2G MAS w/ K&N
-Extreme SMIC
-Upgraded UIC piping w/ ported 2G Elbo
(Exhaust)
-Custom 2.5" Cat-Back Exhaust w/ High-flo cat
(Fuel)
-Manual Boost Controller (15psi)
-Walbro 255 HP Fuel Pump
-Denso 550CC Injectors
-Buschur Racing FPR
-Apex-i Super AFC
(Drivetrain)
-ACT 2600 Clutch
-ACT Flywheel
Goodies:
6-Bolt block/4-Bolt rear
Transmission Rebuilt by PSi @ 100K miles
6-Bolt swap @ 100K miles
110K miles on car
5-speed
Bad:
Possible broken piston ring. (Oil pressure high, popping dip stick at full boost).
Dent in hood
Dent in fender
the only part that worries me is in bold.......your thoughts?
Old 11-03-2004, 11:13 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Re: your input
I would say go for it.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 11-04-2004, 12:37 AM
joemathews's Avatar
joemathews joemathews is offline
Re: your input
If you know anything about cars and can fix that yourself in a few days, that would be a great deal. That car has all the foundation for a 16g or bigger to run 12s or lower if you fix whatever piston ring problem there is.
1996 Eagle Talon
Old 11-04-2004, 09:12 AM
LXDSMXL's Avatar
LXDSMXL LXDSMXL is offline
Send a message via ICQ to LXDSMXL Send a message via AIM to LXDSMXL Send a message via Yahoo to LXDSMXL
I say go for it
I say go for it, if it doesn't work out you could get your money back selling all the parts individually 2,000 is not bad
Old 11-04-2004, 12:22 PM
well i know plenty about cars and how to fix them but i really dont want to have to swap another fucking block......its just GAY labor......not to mention high oil pressure can be caused by a number of things, fried rings, partially spun bearing, etc......i guess i want input if you think its worth purchasing and then having to fix the shit right away
Old 11-04-2004, 01:25 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: your input
buy it and get a buscher race built short block swap that in and put on a 16g
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-04-2004, 01:56 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: your input
my guess is that the PCV is blocked off, adding power, but putting too much pressure in the oil system, popping the dipstick out. ask about that.
Old 11-04-2004, 09:18 PM
Re: Re: your input
lol as much as i would love to do that (i would slap on a larger slug then a 16g), i dont want to really buy another money pit car.......looking to get something fun really, my last car was enough money pit for me, i will be leaving the country in 2 years so i dont plan on modding really
Old 11-04-2004, 09:19 PM
Re: Re: your input
thought about that......but high oil pressure wouldnt pop the stick, its air pressure
Old 11-04-2004, 09:21 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: your input
Buy it.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-05-2004, 12:55 AM
george536's Avatar
george536 george536 is offline
Re: your input
Its worth it. Has alot a nice amount of mods in it already. Can get your money parting the whole car out if you dont want it anymore.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
