Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-03-2004, 08:49 PM
hillbillyboostin hillbillyboostin is offline
Lightbulb need help with my sandwhich adapter.
i bought a sandwhich adapter off of summit. it has to ports and wondering is one for input and the other and output. if one is for and output do i run my drain line threw it or do i run it to the oil pan. info would be appreticated.
Old 11-03-2004, 11:33 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: need help with my sandwhich adapter.
Come on! Need more info people. What the hell does a drain line have to do with it. What is this for, oil filter relocation? Oil cooler? Some other funky BS that involves the oil pan? HElp us help you. 2 lines aint gonna cut it
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-04-2004, 12:31 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
oooh kevins getting frisky!
to answer the queston, the drain/return like always runs to the oil pan, or usually. on the sandwich adapter, either port should work for your feed line, just keep the cap/screw in the other one and you will be fine
Old 11-04-2004, 10:48 AM
AF - Advisor
So I take it this falls under my "some other funky BS" catagory and this is part of turboing an NT car or something. If thats the case, I would think you would want to take oil from after the filter. Which I believe only one of the ports would provide.
Kevin Jewer
