Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-03-2004, 06:39 PM
Lychus Lychus is offline
Angry Check Engine Light and ABS Light!?!?!
What's up guys. Maybe you guys can tell me what the problem is and how much i should be charged for the job. Basically my check engine light comes on almost instantly after i turn the car on. It pisses me off cause once its on it kills my V-tec and it usually happens when i want to race. If i turn the car on and off enough times it goes away but now lately it doesnt go away at all and i refuse to damage my starter just to get rid of the check engine light. Also my ABS light goes on. But my breaks dont do anything weird, no noises orweird movements. Any ideas!?!?
Old 11-08-2004, 09:31 PM
JDM00CivicEX JDM00CivicEX is offline
first thing you might wanna try is resetting the ecu. disconnect your negative battery terminal for about 2mins, then reconnect and start your car and see what happens. if same thing happens, then take it to autozone and have them run an OBDII test on it. its free.
Old 11-10-2004, 12:22 PM
sivic02's Avatar
sivic02 sivic02 is offline
Re: Check Engine Light and ABS Light!?!?!
on most cars you can connect 2 pins from the ecu and turn the key and the check engine light will blink out codes, i have no clue which pins to connect on your car but you might be able to call honda and find out. But if autozone does it for free then id say go with it.
Old 11-11-2004, 12:45 AM
Poison Rice Poison Rice is offline
Send a message via AIM to Poison Rice
I an tell you if its an older car, like my 89 AstroVan (fuel injec) Its the top right. put the pins in and it will give a "12" code twice then the real code. Get a pen and paper ready.
Burnout: Ultimate show of power
Drifting!
Gopeds!
Old 11-17-2004, 12:12 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
you can check the codes yourself with the connecting pins thing^^^ if its obdI 96 and older dont no what u drive but on the 3rd gen teg's it under the dash pass side. haynes has a mnual for engine trouble code that will tell you everything for every car
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
