Old 11-03-2004, 05:12 PM
jmast22 jmast22 is offline
Unhappy 99 Cavalier help replacing window motor???
help,
Replacing window motor in 99 cavalier. i have the door panel, clear membrane, and a couple of the rivots drilled out. need help from here.
joe
Old 11-04-2004, 03:42 AM
kiwicav kiwicav is offline
Re: 99 Cavalier help replacing window motor???
http://www.a1electric.com/s10motor.htm
Old 11-12-2004, 08:19 PM
irishgangsta42 irishgangsta42 is offline
take the door panel off take 2 10 mm bolds out of the window hold the windown up with something then there should be 4 rivits holding the regulator and on rivit by the motor so wizz them down to nothing then use a punch and bang them out then take the other 2 10 mm bolts holding the regulator in it then you should be able to take it out then there will be 3 rivits holding the motor to the regulator get them 3 out then there will be 2 rivits holding a bracket on the old motor you need that and put it on the new motor use 2 new rivits to hold the bracket to the new motor and then use the nuts and screws givin to you with the new motor to hold it to the regulator then you should be able to put it back in then put the 5 rivits back in then the 2 10 mm then window back on and you should be all set
