Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 11-03-2004, 04:38 PM
ATMDC's Avatar
ATMDC ATMDC is offline
Clicking in engine 95 trooper
we were changing the plug wires in a 95 trooper and we couldnt tell if we were putting them in the right place, well we heard a ticking noise when the engine was started but couldnt remember if it was there before, is this normal? if not, whats wrong?
Old 11-03-2004, 08:42 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Clicking in engine 95 trooper
specifically what area of the vehicle is the ticking comming from I would assume engine but top bottom front rear NEED MORE INFO
Old 11-05-2004, 10:50 PM
ATMDC's Avatar
its like a time bomb tick sound, it sounds like its coming from the mid right section where the plugs go
Old 11-11-2004, 11:43 AM
Stereophile33 Stereophile33 is offline
Ticking Noise in Engine
Early and mid 90's Troopers were notorious for having stickign lifters. I was told to run good synthetic and a mobil 1 filter. I have go 230k on my 95 trooper. Replaced the lifters once. Runs like a champ.
Old 01-06-2005, 08:10 AM
gotdurt gotdurt is offline
Common problem, do a search for TSB's on the internet, maybe on this site, you'll find it. Try some "Seafoam" in the oil for a while, flush, then go with a low cold-weight synthetic (indicated by the first number) like 0w-30 (Mobil-1 in the tsb), 5w-30, 5w-40, etc. Avoid 20w-50 like the plague! I've had good luck with 5w-30 Mobil 1 and Rotella T Synthetic 5w-40.
Old 01-08-2005, 12:49 PM
troop94bc troop94bc is offline
I have a 1994 Isuzu Trooper and had a clicking (very loud), it was the timing belt tensioner. Check yours out before someone has you replace the motor. Good luck!
Old 01-08-2005, 06:35 PM
Re: Re: Clicking in engine 95 trooper
Actually, that is another common Trooper issue, enough so that Isuzu updated the part. So, should anyone have it replaced (it's a good idea), make sure and get a new genuine Isuzu tensioner. The symptoms of this though sound different than the clicking lifters, it's more of a rythmic rattle that comes and goes, usually at idle. Sounds something like a diesel. Eventually it will become constant, but try not to let it get that far!
