Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-03-2004, 01:49 PM
carpaltunnel carpaltunnel is offline
2001 Impala radio goes to static when r defrost is on
When the motor is running and you turn the rear window defrost on, The radio goes to static. If the key is on accessory, No static. The cd player works fine, So I am thinking that it is somewhere in the antenna when the defrost is used. Anyone else have an idea? I have checked fuses, They are no where near each other. The only thing I have figured is the relay clicks when the rear defrost is on, But the same thing occurs when I have the defrost on in my 2003 GMC truck, So I didn't think this was unusual. I would appreciate anyones help out there.
Old 11-03-2004, 09:34 PM
troy1 troy1 is offline
AF -Advisor
The Antenna is part of the rear defrost if any lines are broken the radio will sound bad
Old 11-19-2004, 02:59 PM
Shadetreeme's Avatar
Shadetreeme Shadetreeme is offline
Re: 2001 Impala radio goes to static when r defrost is on
I have the same problem. With static while the radio and the defrost are ON. I think it is because the antenna and the defrost wires overlap each other in the rear window causeing interference. I don't know how to remedy this.
Old 03-12-2005, 11:13 PM
camcam33026 camcam33026 is offline
have same problem with am radio. dealler doesnt have solution either
Old 03-13-2005, 03:58 PM
rtebeau rtebeau is offline
Have the same problem on 2002 - I thought it was because I used an after market radio (SONY XM). Are you using the factory Delco radio? They do use the same wires for antenna and defrost.
Old 03-14-2005, 06:47 AM
Static while defrost is on.
Running the factory cd radio. I hope to get a cass/cd stock radio soon.
