Old 11-03-2004, 12:54 PM
mike3028 mike3028 is offline
electric window motor
my 95 needs a new window motor. how hard is it and does anyone have any tips? thanks mike
Old 11-03-2004, 03:49 PM
busa_4 busa_4 is offline
Re: electric window motor
pull the door panel and unbolt the motor.
Old 11-03-2004, 06:03 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Motor assblemy is riveted in.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 11-03-2004, 07:26 PM
drill out the rivets. you can purchase a rivet gun at any tool store. your most likely going to need big rivets. make sure the rivet gun you purchase can hold the bigger sized rivet die.
Old 11-03-2004, 10:12 PM
HanktheHound HanktheHound is offline
I replaced one in my 93 and used short bolts instead of rivets to put it back in. It worked great and will be much easier to take off if there is a next time.
Old 11-04-2004, 05:26 AM
Good point,I have done this also.
Click here
My $12.00 Sunfire
Old 11-04-2004, 06:55 AM
That Is A Good Idea. Rivets Are A Pain. I Would Go With That Method.
Old 11-04-2004, 09:41 AM
Mikado14 Mikado14 is offline
yep, 1/4" bolts and put the head towards the door panel.
Old 11-04-2004, 06:29 PM
Make sure the bolts aren't to long though.The window regulator needs to clear the bolts,or your window won't go up and down the whole way.
Click here
My $12.00 Sunfire
Old 11-04-2004, 08:13 PM
thanks to everyone, it was alot simplier than i thought. i had some 1/4" screws and ground the heads down to about the same height as the head on the rivets and put them in with the heads out. put nuts with lock washers on and is good as new! thanks again everyone
