Old 11-03-2004, 12:44 PM
mar120suz mar120suz is offline
98 S10 heater problems
I have a 98 s10 I am having problems with the heater which just started. the temp gauge goes up to about 210 then back down to 100 and of course it never stays at the normal temp. It does not matter if I have the heater on or off, every now and then when it gets up to 210 I have really good heat for a few minutes then the temp goes back down to 100. replace the theromstat and that did not help at all.
I hope someone knows the fix. Any help would be great
Old 11-03-2004, 03:51 PM
busa_4 busa_4 is offline
Re: 98 S10 heater problems
make sure your coolant is full. check your water pump flow. your water pump might be taking a dump.
Old 11-05-2004, 12:21 PM
I have check both and they are good. It seems to heat up for a while at high RPM but I have also noticed that thier is air comming out on the drivers floor vent when heat and ac are off.
Old 11-05-2004, 01:54 PM
sounds like a symptom of air in the system. did you fully bleed the coolant system?
Old 11-05-2004, 03:23 PM
no I have what is the best way to get the air out of the system
Old 11-06-2004, 02:24 AM
Mindjob360 Mindjob360 is offline
I just had the same problem on my '96 grab your fan and spin it if it keeps spinning the fan cluch is bad costs about 50 dollars and takes about 1/2 hour to do
Old 11-08-2004, 07:34 AM
bedori bedori is offline
had the same problem was my water pump going out. replaced it and now heater works great good luck
Old 11-08-2004, 08:02 AM
busa_4 was right I had air in the system after I got the air out it works great again. Thanks BUSA_4
Old 11-08-2004, 10:38 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Make sure you swap on the new rad cap.
That is how air gets into the system. And don't get the faulty AC Delco, get one from Autozone.
1995 Factory Blazer Service Manual for sale, PM if interested.
