Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-03-2004, 08:51 AM
Markwg100 Markwg100 is offline
Rattling Noise
I have a 98 Jetta GL. When I rev the engine, I hear a rattling noise for the first couple of minutes I drive the car, then it goes away. It sounds like it comes from underneath the front/center of the car. I recently had the exhaust replaced, minus the catalytic converter, which the mechanic said was OK. I assumed the sound was a hole somewhere in the exhaust because I knew I had some, but it is still there. It does go away after a couple of minutes. Any thoughts?
Old 11-03-2004, 09:44 AM
miro1118 miro1118 is offline
Re: Rattling Noise
Check the heat shield on the cat.
Old 11-03-2004, 10:36 AM
Re: Rattling Noise
WHat does the heat shield look like?
Old 11-04-2004, 07:54 AM
Re: Rattling Noise
Its metal with holes on it. Look on the cat you should see it
Old 11-04-2004, 09:15 AM
Re: Rattling Noise
Thanks for your help!
