Old 11-03-2004, 08:46 AM
earp earp is offline
Hints
Hey friends.... I do have a 2000 blazer V6.
I got this problem when idle with a gear on. The RPM stays fine but aprox every other 2 minutes they go down, as the engine will turn off, but just 2 senconds later it goes again to normal levels.
It's a issue like having a bad spark plug, but i check them loke a month ago and they were fine and as the problem happens every 2 minutes i imagine it could be something else.
Addiitional, when driving a high climb you cant feel like the engine has not enough power like and you can feell the RPM problem highier.
the car has 50 M Kms.
any guess? what should i check?
tx
Old 11-03-2004, 10:03 AM
Fireplug Fireplug is offline
Re: Hints
fuel filter
Old 11-03-2004, 10:50 AM
mrfirebird mrfirebird is offline
sounds like the compressor kicking in and out. turn off the air or defroster and see if it still continues.
Old 11-08-2004, 09:02 AM
Re: Hints
it's not the air conditioner.. as i turned off and the problem persists..... Can anybody tell me where is the fuel filter so i can take at look at it?
Old 11-08-2004, 09:08 AM
Mikado14 Mikado14 is offline
Re: Hints
Should be tucked inside the left frame rail midway between the front and back or approximately in line with the drivers door.
