Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-03-2004, 08:17 AM
90sr20det240 90sr20det240 is offline
Question HELP my car won't start
alright...... i have a 240sx with an sr20det in it, well lately the car won't start right away, it just cranks. it only started doing this lately and i live in kansas so its gotten cold lately. it first did this soon after i installed my turbo timer and i thought it might be related so i uninstalled it and it still won't start right away. the starter is fine because it cranks just fine but won't fire, any ideas on what i need to do to fix it.....thanks
Old 11-03-2004, 09:07 PM
mrx7255 mrx7255 is offline
Send a message via AIM to mrx7255
Re: HELP my car won't start
did you check your injectors?
Old 11-03-2004, 09:15 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
MAF, check it!!, vacum lines...etc??
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 11-03-2004, 10:51 PM
ya i thought about the injectors, so i went and bought some injector cleaner stuff and its runnin through now, we'll see if that helps any
Old 11-03-2004, 10:58 PM
ProbeKiller ProbeKiller is offline
Just a thought... Next time you go to start your car, turn the key on and let it sit for 15 - 20 seconds to insure your fuel line psi is all the way up. If that does the trick then you will have a place to start
Old 11-03-2004, 11:28 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
So I don't have to start a new thread, My car wouldn't even turn over for about 4 tries, then it started right up. I heard a little clicking sound but the car wouldn't even turn over. Everything is stock, and it only has done this once so far, but I would like to take care of it before it becomes a bigger problem. Does anyone have any ideas? Just in case, it's a 1991 240SX SE.
Old 11-03-2004, 11:47 PM
OH SH*!!! Hopefully it doesn't turn into the Fk'n nightmare mine has!!!
Okay, first time it was corroded connections on all positive terminals (from a bad battery)
Start by cleaning all of your terminals especially the ones on the starter. After that I went a good 6 months without the problem re-occuring.
Currently I'm having a nightmare with previous owners accessory wiring.
Right now I'm going through this crazy stuff where I have to wiggle the wire bundle leading into my relay/fuse box. I'm super busy right now so I don't have the time or the patience to take all the wire apart and rewire/clean her up. Just a heads up for yeah.
Old 11-04-2004, 10:30 AM
S13wanabe's Avatar
Thanks ProbeKiller, I guess I'll get to work cleaning terminals, and checking wires. I have a little spare time, so better to catch it early. Thanks.
Old 11-04-2004, 11:04 AM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
I just had this problem On my KA-T. It turned out to be a bad coil. Way to check your coil:
1)Take the coil wire off the distributor.
2)Set it close to a ground point(any piece of metal connected to the body).
3)Try to start the car and watch for the wire to arc onto the ground point.
4)If it doesn't, you have a bad coil or bad wiring.
I'm not sure about the SR guys. Sorry.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 11-04-2004, 11:06 AM
Yo, S13, let me know if cleaning the terminals up works for yeah, especially the ones on the starter.
Old 11-04-2004, 05:05 PM
kingcarm kingcarm is offline
Battery maybe. Check the terminals for corrosion. If there is corrosion use sandpaper and clean them. You many need a new battery. Try putting a charger on the battery and see if that works.
Carm
My 1991 240SX SE
