Old 11-03-2004, 05:37 AM
justin_t_ justin_t_ is offline
sound system, subwoofer
Hi,
Does anybody know how to make a soundsystem or subwoofer?
thanks
Old 11-03-2004, 08:36 AM
Alien's Avatar
Alien Alien is offline
Re: sound system, subwoofer
I believe hoppin hydros did some
working on:
Nothing, got a new house and need to get a new workspace.
Old 11-03-2004, 09:50 AM
008's Avatar
008 008 is offline
I made some nice looking ones by shaping the little plastic domes that some medicine tablets come in. I forget which brand, though. Might've been the kids' medicine, even.
Old 11-03-2004, 10:27 AM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
Re: Re: sound system, subwoofer
He asks how to make them, not how to buy them
Anyways, I know a method. I use it as well and it works pretty good, though I'm not done with it yet. I use Fimo that needs to be heated in the oven to get solid. I make a half sphere of Fimo. I heat that up. After it's done I make a half sphere again in the top of the big one using my dremel. This way I get the inside of a sub or speaker. This will serve as a template. I put BMF on the top. On top of that I put again some fimo. After that is heated I pull of the top of fimo and I got a perfect sub.
Of course this all goes with some sanding and stuff. The speaker needs to be sanded and made flat on the inside, but that's not a lot of work.
This all isn't really clear probably. I'll post some pics if necessary (I just need to make them still )
Old 11-03-2004, 10:30 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Bas. my aunt makes craft stuff out of fimo..i never thought of that. awesome idea
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 11-03-2004, 12:53 PM
DukeMan's Avatar
DukeMan DukeMan is offline
Iīve also been thinking about making my own subs, so I started experimenting with it and I came up with several methods. The one I liked best, the "heat and form", I belive itīs pretty similar to Basī method. I haveīnt had the time to complete any sub yet but as soon as possible Iīll finish it and post some pics. The idea is to simply heat up some styrene sheet and form it over somthing round, like the glass ball I used (in reality, the sub would be 10", so make sure to find something with a proper diameter). The other metod is basically the same, only that I use Milliput instead of styrene, and the sub-frame is offcourse styrene aswell.
Make sure to heat the styrene for a quite long time, about 30-60 sec so that itīs completly warm, then itīll form better.
Alu BMF was used for the membrane.
Here it is (the Milliput one), temporary installed in the temporary trunk of my R34.
Regards, Fredrik
/Fredrik
Current Projects:
-ī70 Camaro Z28 (Baldwin Motion hood wanted!!!)
-ī32 Ford Roadster (on hold)
ī69 Camaro thread
Old 11-03-2004, 01:35 PM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
that's gotta go in the "how-to" fo'sho!
Ed-
Old 11-03-2004, 04:16 PM
DukeMan's Avatar
Think so? How do I post it in there then? Also, maybe I should take some pics of the final result so that people can see how it turns out.
/Fredrik
/Fredrik
Current Projects:
ī69 Camaro thread
Old 11-03-2004, 04:34 PM
I already planned to make a how to on my method. I just didn't came around to do it. I'll try to put on a how to within a couple of weeks.
Old 11-03-2004, 07:46 PM
white97ex's Avatar
you two should get together and make a joint how to, just two methods in the same thread
Old 11-04-2004, 12:01 AM
Midnight Racer's Avatar
For sun's I just use headphone spaeaker's.They look like 12" and you get get them cheap, plus you can make them work in your model.
Old 11-04-2004, 12:55 PM
Nobbys Nuts Nobbys Nuts is offline
Thumbs up Re: Re: sound system, subwoofer
I like this idea. Requires further investigation. Many possibilities.
Good ideas guys and I agree that you 2 should put your ideas in one thread for all to have a choice.
Cheers
Tony
Old 11-04-2004, 06:24 PM
aN4rK1's Avatar
aN4rK1 aN4rK1 is offline
Awesome man, definetly how to material
