Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 11-03-2004, 03:53 AM
marklfc77 marklfc77 is offline
Clutch Cable 97 Corolla
Hi as I know nothing about cars how do you know when it is time to replace you clutch cable? is there someting you can do to check it yourself?
Thanks
Old 11-07-2004, 02:13 PM
sjr8ut sjr8ut is offline
Mine is an automatic--but I thought that these cars have hydraulic clutches. If that is the case, then I don't think you have a clutch cable. Someone let me know if I am wrong.
Old 11-08-2004, 10:16 AM
outthere2's Avatar
outthere2 outthere2 is offline
Re: Clutch Cable 97 Corolla
You are correct sjr8ut, the clutch operates Hydrolicly .
The Shift linkage is cable driven. No adjustment of the clutch is needed.
Outthere Too..
Old 11-30-2004, 01:47 PM
thehoot thehoot is offline
marklfc77, if it seems like you need to replace your clucth cable, maybe you need to bleed the hydraulic line to the clutch. Pick up a haynes manual from your local auto parts store. Its really easy to bleed clutch. it does take 2 people though (one to push the clutch, the other to tighten and loosen a nut).
