I once saw forum that showed that how to change the brake rotors and pads on a vr-4 and i was going to c if you guys now what that forum was called (the fourm had pictures and everything) or can tell me how to change my brakes. I have changed brake pads on other cars and i just want to make sure i am doing it right on this car and i am not leaving any of the steps out.
THANK YOU PLEASE HELP ME ASAP. PLEASE PLEASE |
Re: How To change brake rotors and pads?????? HELP HELP
Check the FAQ, it's there
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
what is the name of it because i couldent find it??????
Changing brakes: http://www.stealth316.com/2-rotorpads.htm
or http://www.team3s.com/~egross/3S/Mai...Pad/index.html
Thank You Thank You Thank You
Is the process the same for VR4s, SLs, and bases?
Yeah, calipers may be marginally different, as the vr4 calipers are the most complex caliper I've ever worked on...but the whole process is the same.
my screw in the back of my calipers is not turning, do u know what i can do to make that damn screw to turn???
its rusted or i dont now what hell is the problem with it i was about to just take reanch and take a hammer and hammer until the screw movs what do u think?? |
Are you sure you are turning it the right direction, remember you aren't facing it...so you should be turning the opposite direction than normal.
Are the 93 VR4 callipers as big as the 94+ ones?
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Re: Re: How To change brake rotors and pads?????? HELP HELP
get some sort of rust penetrator solution. a must have when doing engine work, exhaust work, brake work, adn chassis/suspension work, as these are the parts of the car that are most exposed to the elements, and therefore most susceptible to rust, grit, dirt, grime, and just crap. so get some sort of rust penetrant, some WD-40, and brake cleaner.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
I put a wrench on mine and beat the crap out of them with a hammer. They came right off. And the VR4 calipers are the same for all years, but the rotors on the 2nd gen are bigger, along with different mount bracket to accomdate the larger rotors
