Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-02-2004, 04:38 PM
Initial_D Initial_D is offline
Question 10000rpm on JDM b16a
okay guys,
one of my friends bought a JDM b16a for his EK9. He want to know if it possible to make this engine able to rev up to 10000 rpm safely ? however this is his only car for his daily drive to work (( about 100 km from his home ))
his budget about 5000$ is that enough to do this?
what parts need to be changed ?
please help him cuz he is my best friend
Old 11-02-2004, 04:54 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Yes it possible, just get Valve Springs made for that RPM redline, titanium retainers, valves and a really balanced bottom end.
Old 11-02-2004, 05:24 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: 10000rpm on JDM b16a
Originally Posted by Initial_D
okay guys,
Sounds like a really bad idea for a daily driver to me. An engine with a 10000rpm redline will likely have its whole powerband shifted up past the 6000rpm mark. Meaning he'll probably have to rev to 5k just to keep up with traffic.
What you'll likely need is valves, springs, retainers, resleeved block. That's all that i can think of from the top of my head. I'm sure theres plenty more you can do.
Old 11-02-2004, 05:41 PM
so frrom where he can get these things for his engine ?
Old 11-02-2004, 07:10 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Is he planning on getting cams and/or higher compression pistons too? Because if he's not then there's no point. He won't make any power in the high rpms if he just builds the valvetrain. Sure his motor could withstand being in higher rpms, but it's not going to do anything. There a a bunch of companies that make those engine parts; crower, skunk2, toda, jun, spoon, and more.
Old 11-03-2004, 03:43 AM
CRAZYEG9 CRAZYEG9 is offline
Re: Re: 10000rpm on JDM b16a
A-men to that, without some crazy agressive cams it won't make sence. On stock 2nd B16As the stock cams start loosing torque/power between 7000-7500 depending on intake exhuast setup. Also he will need an agressive port and polish, a big intake manifold+ what everyone else is talking about. Unless your man is a rev happy addict, I wouldn't do this on an everyday car, and good luck merging on the highway with out waking up the neighborhood.
Old 11-03-2004, 06:32 PM
SiGNAL748's Avatar
<at risk of making himself look like a n00b mode>
An motor spinning at 10k is likely to put an extremely heavy amount of stress on the stock motor mounts wouldn't it? I suppose you'd have to do something about that also.
</at risk of making himself look like a n00b mode>
Old 11-03-2004, 07:29 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
noob alert noob alert, jp
i myself wanna build a motor that can rev up to 10,000 rpms one day, i love the sound of a motor that is revving high. in this issue of HCI, they built a 200whp b16 that was revving up to 9500 and i think it would have made power to 10,000.
they had it stage 3 cams, ITBs, it was bored .5mm over, milled head, higher comp pistons. made peak power around 9500 so it easily could ahve been revved to 10,000.
i dont think you would want ITB in your daily driver but it was still a cool article, you would need a very high flowing intake mani
Team Lonely Drivers
Old 11-03-2004, 07:49 PM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
Can I also suggest getting the block blueprinted? Revving that high you want to minamize the movement of the individual parts.
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
Old 11-04-2004, 12:15 AM
diegoaccord's Avatar
diegoaccord diegoaccord is offline
I have a video of a B16A EG hatch doing 10000
P+P head
Cam, sp, ret
Even on a stock airbox.
I think not too many mods need to be done to get it 10K, shit thats my goal on a 2nd gen B16A.
Near stock, my D16Z6 sees as much as 9000, which is about 1800 past the redline. So a B16A should do it easily.
But unless you do have those mods, I would only use that higher redline during 1st, and 2nd gears. It's what I do, unless I'm in a highway race, then I'll use the full 8400(normal rev limit).
My cars:
Civic coupe EJ1. B16A, EG6 cluster. Wrecked/parting.
CRX DX ED8. DOHC ZC, I/H/E.
EJ1 Civic Si . Screw Hatchbacks. Coupes just look better. Period...
Old 11-04-2004, 12:28 AM
you mean balanced, not blueprinted
Team Lonely Drivers
Old 11-04-2004, 02:08 PM
Kven's Avatar
Kven Kven is offline
you dont need to resleeve a b16a; itll handle 10,000rpms fine on the stock sleeve unless you are boosting(even then, because of the b16a's R/S there isnt much side loading force on the cylinder walls). the main thing thatll allow an engine to rev high is valve springs, but id recommend Ti retainers, balanced internals, and cams that will make power that high. high compression pistons arent just for high rpm; they boost overall power, omniman made over 190hp@~9500rpm on stock pistons!
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
