Old 11-02-2004, 04:14 PM
Gotti's Avatar
Gotti Gotti is offline
Got Damn Toolbars
I cant get rid of these toolbars i have in Internet Explorer.... and they're really startin to piss me off
I have one at the top that i cant even right click and remove (if i wanted to every time i opened explorer) and a blue one that pops up at the bottem every single time i open explorer and i have to close it every time.
I've used my Mcafee to get rid of any trojans and "unwanted programs" and then adaware right after. BUT THEY ALWAYS COME BACK!! Sometimes they'll go away for a little while after i do the cleaning and restart but then bada bing bada boom back again. I cant get rid of these motherfuckers
Old 11-02-2004, 06:57 PM
Raz_Kaz Raz_Kaz is offline
Re: Got Damn Toolbars
firewall anybody?
Old 11-02-2004, 09:20 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
try hijack this
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 11-02-2004, 10:57 PM
Fully_Sick's Avatar
Fully_Sick Fully_Sick is offline
what you need to do, is find a tech computer forum and ask them for advice. They told me to get Hijack This and post my print thing
then they said to d/l Ad Aware and SpyBot, these 2 programs together will kill those wak toolbars
otherwise fuck knows
89 Toyota Corolla with 4agze conversion, zzzzzzzzzz
is that a front mount!
Kill list - Commodore VR SS 5L, 2004 Subaru WRX, every model v6 out there pretty much, nissan 180sx with ca18det, mr2 n/a
Old 11-02-2004, 11:39 PM
Gotti's Avatar
ok i'll try using adaware AND spybot... maybe the combination will work
Old 11-02-2004, 11:50 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
wanna know the best solution? stop using IE
www.avantbrowser.com
It's the one I use and I never have any trouble.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 12-18-2004, 03:56 PM
Pavlo's Avatar
Pavlo Pavlo is offline
Go to add or remove programs in controll panel and remove all the programs such as toolbars and crap, then there will still be a folder in C:Program Files\ I usually delet those as well. If there is a massege that the program is being use go to task manager and close any processes that are not needed (usually have the program name as part of the process name) sorry for explaining so complicated, the easiest thing to do is format your computer and just start over (make sure you use at least windows firewall and stop watching porn from bad websites). And IE is a retty good browser just do windows security updates and turn on firewall.
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 12-18-2004, 04:25 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
If they come back on their own after McAfee and adware removal programs, more than like it's an adware program that's installed on your system. Check your Add/Remove programs utility in Control Panel and look for any suspicious programs that might possibly be the culprit. Also, it helps if you remove any internet connectivity while cleaning your computer. Most adware programs "talk" to the ad servers to pipe that stuff over to you. Not much they can do without a network connection. This will keep them from going ballistic on you while you attempt to clean them off. If you're on dialup, just remove the telephone cable from the modem. If your on a network, just unplug the network cable from your network card.
After you uninstall any possible suspicious programs, then run Ad-Aware and Spybot and see if they find anything else. Make sure you have the latest versions/updates for them as well. Also helps to check your Task Manager and see what's running when the ads pop up. It should help give you some clues as to which program(s) are causing the issue and where to find them and what their name/folders are.
Also, it is safe to delete everything in the C:\Windows\Temp\ directory. Nothing in there is necessary and if anything's needed, it's always auto-generated by the program(s) that need the scratch directory when they're run. You can also go to C:\Documents and Settings\ and open the profile directory you use. Make sure your hidden folders are visible. From your profile directory, open "Local Settings" and then "Temp". You should be in a directory tree like this: C:\Documents and Settings\"Profile Name Here"\Local Settings\Temp\. You can delete everything in there as well. And don't forget to clear out your Temporary Internet files directory. There's an option to do that in Internet Options. Delete all files and all offline content. Only thing you should have left after that are cookies. Ad-Aware and Spybot will root out the bad cookies.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 12-19-2004, 04:11 AM
Inferno69 Inferno69 is offline
I ahet toolbars, although I instaled the google toolbar cause I love its built in google search and amazing popup blocker, although firefox still kills IE!
Old 01-04-2005, 07:45 AM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
run adeware and s/b and and then clear out your cookies on your computer thats how they normaly reinstall themselves after you delete them.
Old 01-06-2005, 02:17 AM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
if you still get them, you want to go into your registry and delete them out of HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Explorer Bars
if they are still there, you computer is on crack
Old 01-06-2005, 03:24 AM
my3rdskyline's Avatar
my3rdskyline my3rdskyline is offline
Send a message via AIM to my3rdskyline
Re: Re: Got Damn Toolbars
anything but IE
and you know what.... as soon as you do... all the problems stop. it just takes some getting used to. I know it's hard to let go. but it is better. it really is.
Old 01-06-2005, 05:55 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: Re: Re: Got Damn Toolbars
Originally Posted by my3rdskyline
anything but IE
well actually its a bit deceiving but that avantbrowser is just an IE plugin. So it still uses the IE engine and most likelly all its holes.
So far my fav by far is Firefox. I switched form IE a long time ago and started to use regular Mozilla then when firefox got to a higher build i switched to that and been happy ever since (of course it was called firebird back then and it was not even the first name).
I jut love using it on both my windows and mandrake desktops. It works perfect on both platforms and i could only asume it works just as fine on the other supported ones.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 01-06-2005, 06:12 AM
konqueror for me lynx is a little overboard
Old 01-06-2005, 06:59 AM
Neutrino's Avatar
Yaya Master
eh i never tried that, i heard is supposed to be all that but never really got into it. Plus i use gnome more than kde
so so far under linux i've used netscape then switched to regular mozilla then firesomething
(\__/)
