Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-02-2004, 05:01 PM
Cliff2007 Cliff2007 is offline
How To Center The Steering Wheel??
I have a 1999 Sahara and she runs straight and true. My only problem is that the steering wheel is not centered. Can I center the steering wheel by adjusting the Center Link (attached to the pitman arm) or must I remove the steering wheel with a puller and recenter? I would hate to have to send it in for an alignment. Thanks!
Cliff
Old 11-02-2004, 05:04 PM
addihs214 addihs214 is offline
Send a message via AIM to addihs214
Re: How To Center The Steering Wheel??
I don't know if yours is different, but on my 92 Wrangler, I have to rotate the center link to get the steering wheel centered. There is some movement in the steering wheel if you pull that. There is a notch cut for the horn that gives you some movement in the steering wheel. Just depends how far off it is.
Old 11-02-2004, 05:19 PM
I estimate the steering wheel to be about 20-degrees to the left from center. So If I loosen the clamp on the Center Link and rotate it either out or in, this should help to center the steering wheel with no effect on wheel alignment???
Old 11-05-2004, 03:19 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Should be ok, but watch for getting the turn signals messed up.
*edit*
What I mean is that if you turn the steering wheel shaft, you could get the turn signal release mechanism off by a little.
Old 01-26-2005, 10:08 PM
rob j rob j is offline
Point the weels straight and adjust the tie rod, don't mess with the steering weel. loosten the clamps, use penetrating oil and maybe a pipe wrench and spin the tie rod and watch the steering weel. Don't forget to unlock the steering weel.
