Help with these emissions results...
Hi,
I live in california and I just got my smog check at a test only center and it bearly passed, but I'm scared for the next one. Please look at the numbers and tell me what could cause the high HC and NO. Thanks... 1993 Honda Civic DX Sedan 1.5L 5-Speed non-AC CO% O2% HC CO NO MAX AVG MEAS MAX AVG MEAS MAX AVG MEAS 15 MPH 15.5 0.1 97 21 85 .59 .06 .14 731 150 717 25 MPH 15.1 0.1 62 13 62 .59 .05 .10 798 136 775 1653 RPM @ 15 MPH 2620 RPM @ 25 MPH The car has 210515 Miles on it. Just replaced air filter, gas cap, oil & filter, spark plugs, radiator. I did notice a little leak of oil on the ground. I do need to replace a cv boot, spark plug wires, fuel filter, tires, timing belt & other belts... Any help is appreciated...thanks... |
Re: Help with these emissions results...
Have you checked you 02 sensor?
i'll burn you at the track...........eventually |
no i have not...is it a hard fix?
Not hard.. but if it's messed up it runs about $70+
I think this might be it I had to do a test only about a week ago. I cahnged the Water pump(it was leaking) the thermostat Fixed the timing and at the end we changed the 02 sensor, the car passed with flying colors, My NO was super high before i cahnged the sensor... so that might be the reasonable thing to do... if you want a deeper and more technical explanation talk to GSCivic7 , he can help you out beta' than i can. The 02 sensor is located right behind the radiator, almost under your engine code. Mine is a Civic DX Coupe but it's auto
thanks i'll do that...how can i get in touch with him?
High HC is due the cause of the vehicle misfiring, high nox is caused by the vehicle's cylinders arunning hotter than normal.. possible you may have the beginning of a lean misfire...
what can i do to fix that?
thanks again... |
Check your timing.
![]() Empty Pockets Racing Member #1 |
