Old 11-02-2004, 03:33 PM
SsHaDyGt SsHaDyGt is offline
Lightbulb supercharger pulley installation
ok im about to install my new pulley but im not sure which way it goes none of the instructions really make it clear what i mean is one side of the pulley is flat and one side is curved inward so which way? also when i took off the plastic engine cover i noticed the lines runing on top of the supercharger the fuel lines and one was leakeing they both feel sort of loose how could i tighten them?
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 11-02-2004, 04:00 PM
my 2nd problem i just realized is that i cant break the nut on the pulley loose how can i get it loose or stop it from moving(the belt isnt on and wont fit on)
Old 11-02-2004, 04:05 PM
stlwagon stlwagon is offline
Re: supercharger pulley installation
What type of pulley puller are you using??
Old 11-02-2004, 05:56 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
If you are using a Thrasher or South Florida Pulley, the flat side goes to engine. Thrasher even has their name pointing out.
As far as the nut goes, used inpack. Sprayed it the night before. Came right off. Let's see what everyone has on that.
Old 11-02-2004, 05:57 PM
the one from zzperformance.com
Old 11-02-2004, 06:19 PM
Here's the "rent a pulley" from ZZ
http://www.zzperformance.com/zzp/pro...ley_puller.htm
Old 11-02-2004, 07:32 PM
yes the pulley and puller are from zzp i dont have an impact wrench is there any other way...i need to stop the nut from spinning somehow...
Old 11-03-2004, 07:56 AM
Is the issue that your pulley is spinning while trying to loosen the nut?? If so, wrap your old sc belt around the pulley and grip it with a pair of vise grips. This should hold the pulley in place while you loosen the nut. It shouldn't take that much to loosen it. Mine came right off with just a 21mm wrench.
Old 11-03-2004, 10:18 AM
i might try something to that effect... my old sc belt wad destroyed because autozones pulley got stuck
Old 11-03-2004, 12:46 PM
Let us know how it turns out. One pointer on your pulley install-- be very careful to exert an even amount of force on the puller when removing the pulley. The M8 studs have a tendancy to shear off if you really crank on it. Good luck.
Old 11-03-2004, 02:41 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Just get some rubber gloves on and hold the pulley by hand and have a buddy try to losen the Nut in the center on the pulley...the nut does not hold the pulley on, it has a hole in the center of it and it is just a breather nut....also make sure you use alot of ANTI-SEIZE.
ClubGP Member 6530
Since 2001
Old 11-03-2004, 09:52 PM
I got it off got the new one installed and now im hearing a sort of racheting sound and a small sqeel from the sc snout i read that the coupler goes on these could it be that??
Old 11-04-2004, 06:46 AM
Squeal could be caused by not having the pulley completely seated. It has to be flush with the end of the s/c shaft. If it's off even a little bit, the s/c belt won't align correctly.
