Old 11-02-2004, 01:30 PM
astro1911 astro1911 is offline
biggest tires on a 01, z71
Hi,
Whats the biggest tire size i can put on my 2001, z71 ?
sorry if this has been asked a million times
thanks
Old 11-02-2004, 02:39 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: biggest tires on a 01, z71
305/70/16 with the torsion bars cranked a good bit.
285/75/16 will fit with virtually no modifications.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 11-03-2004, 01:27 AM
what does cranking torsion bars envolve and is it bad to do?
Old 11-03-2004, 08:55 AM
jeverett's Avatar
It involves going under the truck, and adjusting the torsion bar bolts..you can see them once you slide under. If you tighten the bolts, it raises the front of the truck up a little. If you crank them too much, it will wear your tires on the outside, but if you just do it a little to make sure you have enough clearance, they should be fine. Mine are cranked 4 turns.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 11-15-2004, 06:59 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
I have BFG MT's on my truck that are 255/85/16 which are 33.3" tall when new and i did not have to crank the torsion bars to get clearance although i did to level out the truck
Old 11-15-2004, 07:03 PM
kenny-1907's Avatar
The 255/85/16's are nice because you get the height without all that width, Don't get me wrong there is nothing wrong with wide tires it is just that with that kind of width and any amount of snow you damn near have to have it in 4wd just to get around. Also it is easier on gas with narrower tires , although when you are running 33's it does not make much of a difference lol
Old 11-16-2004, 03:31 PM
Limited5.9Cherokee Limited5.9Cherokee is offline
Banned
the best thing to do any time you touch your torsion bars is to get your vehicle aligned. it will save you money in tires
