Old 11-02-2004, 11:24 AM
dusti dusti is offline
Unhappy 1997 gmc safari won't start??
hello my van won't start burt if i spray starter fluid in the filter it starts and runs great but as soon as i turn it off it won't start back up after about 20 minutes or so. i think its the fuel pump but it ingages when i turn on the key i can hear it would anyone happen to know if it could be the fuel relay?? don't wanna buy a pump if its not out please help?
Old 11-02-2004, 12:43 PM
my3sonburns my3sonburns is offline
Welcome to the world of fuel delivery problems on this vehicle.
I had/still have the same problem with a 1995 GMC Safari.
Changed the fuel pump and it worked for another 20,000 miles. Then started experiencing the same problems. Van would turn over, but would not start.
I changed the fuel pump and it worked great for another 82 miles. Same problems, except now it will start up and then shut off while driving. I turn the key back and forth a few times and the van will start back up. There is absolutely NO normal pattern as to when and how it starts. Changed the fuel pump relay. NO AVAIL!
Started tracing the wiring harness and noticed that I was only getting 8.5 volts to the pump when the van would not start. Even after changing the relay, it still didn't help. When the van started, I was getting 12.5 volts to the pump.
I'm beginning to think I need a new computer as it supplies the 12 volts to the gray wire going to the pump.
There are SOOOOOOOO many people with the same problem that you are having. Some change the fuel pressure regulator, others have had problems with the ground wire for the wiring harness and still others needed a simple fix like the neutral safety switch. I wish I could help you more. But this is a COMMON, COMMON, COMMON problem with these vehicles.
Old 11-03-2004, 03:17 PM
slim84maro slim84maro is offline
Send a message via AIM to slim84maro
Re: 1997 gmc safari won't start??
haha i have that problem now. here my story
ok driving around fine get to a store mom runs in for a couple mins. i stay in van with it on. starts idleing rough, then dies. now doesnt start. turns over but no start. had to have it towed back $125 for that. does this sound like a fuel probel? i does to be.
check out www.v8havoc.com
