Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 11-02-2004, 09:12 AM
curbie curbie is offline
Banned
Send a message via MSN to curbie Send a message via Yahoo to curbie
Exclamation Wire Harness Needed!
Is there any way possible I could find the wire harness for my 2000 Tiburon? I found out after replacing a turn signal bulb that someone cut into the wires (splicing them together) and the wire from the harness itself is VERY VERY VERY small. They've somehow managed to get it spliced to the other end of the wire, but I wanted to get ahold of a new harness with more wire on it. In case the splice fell apart somehow. I've looked on eBay and couldn't get anything. Unless I've tried using the wrong words to search by. Any help or suggestions?
Old 11-02-2004, 09:13 AM
Banned
I forgot to add that the harness I need is for the right turn signal lamp. That might help!??
Old 11-02-2004, 10:09 AM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Try a junkyard. They might cut the pigtail off for you. You would have to buy the whole engine harness in order to get that pigtail from Hyundai.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 11-02-2004, 07:53 PM
andrew348 andrew348 is offline
Re: Wire Harness Needed!
curbie
i have a few used harnesses mabye you can be more specific
which turn siginal front rear left right
is the splice where the bulb socket meets the harness or where the tail lamp harness meets the body harness
let me know i will be more than happy to help u out
also if you can find your way around hmaservice it would help things if you can get the exact connector number from the wiring diagram
Old 11-03-2004, 09:29 PM
Banned
Andrew> I need the harness for the front right turn signal lamp. I'm not sure of the exact part number...sorry As for the splice....it is where the bulb socket meets the harness. I need more wire so I can get a better splice. I'm just afraid that it might come loose one of these days??
As for the other suggestion made my lowsonoma1999> I shalll check into a junkyard as well. Thanks for that idea, I didn't think of it
Old 11-09-2004, 09:43 PM
i have the connector its froa 2000 elantra it should be the same you want me to mail it to you
Old 11-13-2004, 07:40 AM
Banned
I suppose you could mail it to me, but I wouldn't know if it would fit for sure....can someone confirm this? Umm...my email is [email protected] - I don't think I want to post my snail mail addy.
Old 11-17-2004, 08:17 AM
Banned
Is there any follow-up on this thread? Anyone else might know where I can get the harness for this?
Old 11-17-2004, 07:50 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
dealership?....
almost that time
my sig made mommies cry, thats why i had to change it..
Old 11-17-2004, 08:52 PM
Banned
I could try the dealership nisco, thanks I just haven't had any luck with junkyards - don't see too many 2000 year Tibs in junkyards... none at all in fact. Maybe if I wait another 10 years?
Old 11-17-2004, 10:32 PM
Tib Guy
if not the dealership.. id go with ebay... if no wiring harness.. jus get a whole new head light assembly... stuff i cheap on ebay
almost that time
Old 11-22-2004, 08:59 AM
Banned
Guess I will have to look @ a junkyard....eBay has nothing
