Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 11-01-2004, 08:56 PM
slammedscion slammedscion is offline
help picking new car
I am wanting to buy a new car i have between $5000-$7500 to purchase the car and will save for the engine parts. I was wondering which would be a better car to race.I am plannin on putting at least 5-6 grand in the engine. I like both the acura integra and the honda prelude i am wondering which would cost less to make a 11-12 sec car that will make a good daily driver thanks sorry if im in the wrong forum.
chris
Old 11-01-2004, 08:57 PM
Mediocrity's Avatar
Mediocrity Mediocrity is offline
Send a message via AIM to Mediocrity Send a message via MSN to Mediocrity Send a message via Yahoo to Mediocrity
Re: help picking new car
Why a Honda?
It would take way too much time, effort, and money to put those into the 12s.
"ill go strate to ur house and pop my hood show u my sr20det and say see fool now lets canyon and hope u can keep up" - zeroneonzn
Old 11-01-2004, 09:01 PM
CassiesMan's Avatar
CassiesMan CassiesMan is offline
AF Vendor
Send a message via AIM to CassiesMan
I think a turbo, i/e/h/c, and a damn good driver can drop a teg GS-R or, if lucky enough, Type R into the high to mid 12s? I say look on Autotrader for a GS-R or Type R, if thats what you want. Personally, I'd go with a 1st or 2nd Gen Eclipse GS-T or GS-X, but thats me.
2006 Redline Red Nissan 350Z Base
K&N|Falken
I am just that JDM tight, yo.
Old 11-01-2004, 09:19 PM
yea i knew some one would say y a honda or acura but i like them yea i was plannin on spending quit a bit im going to turbo, bore new cams crank all sorts of stuff like that im also kinda looking at a rx7 its a 1995 both of the others i would like 96-2000
Old 11-01-2004, 09:24 PM
CassiesMan's Avatar
AF Vendor
If you do all of that to a Teg GS-R or Type R, I'm sure you could get it into the 12s. I'm not that knowledgable on Asian Imports, but I'm pretty sure that would work. Personally, I know I'll cath flack for this, but I'd go with a 'Teg, I think they look better than RX-7s, but thats just me.
K&N|Falken
Old 11-01-2004, 09:26 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
how many miles does the RX7 have? and how much?
my cardomain
Old 11-01-2004, 09:40 PM
91300zxtt's Avatar
91300zxtt 91300zxtt is offline
Send a message via AIM to 91300zxtt
well your best bet would be either like a gsr or maybe even civic si if you want handa/acura. that rx-7 most likely has some major problems if its going for that cheap though
Old 11-01-2004, 09:42 PM
its mainly highway but a little over 100000 he said around 7500
Old 11-01-2004, 09:43 PM
i have heard its got some problems but dont really care since i will be rebuilding the engine top to bottom and same with the tranny
Old 11-01-2004, 09:47 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
geez, it'll cost way more than 5-7k to get a teg into 12 including cost of car, just get a 1g DSM all wheel drive turbo, or maybe mk3 Supra turbo might not hit 12's but you'll be fast from a roll if you mod it right.
Old 11-01-2004, 09:48 PM
a twin turbo rotary must be rebuilt at about 90,000 miles. and a rebuilt will cost like 3 times the price of a piston engine.
my cardomain
Old 11-01-2004, 09:54 PM
i would recomend a 86-91 RX7 and swap a V8 engine into it.
my cardomain
Old 11-01-2004, 09:57 PM
Amish_kid's Avatar
Re: Re: help picking new car
ha it doesn't need to be rebuilty at 90k miles, if it was properly maintained and not abused it can last longer than a piston engine plus
As a consolation, BEST case scenarios IF all these parts are in good condition:
  • apex seals (check wear spec)
  • apex seal springs (should be good)
  • corner seals (rubber plugs need to be replaced, but metal outer "shell" should good)
  • corner seal springs (should be good)
  • oil control o-ring metal casings (iffy - soft oil o-rings seals need to be replaced)
  • side seals (should be good)
  • side seal springs (should be good)
  • rotors (make sure ALL seals slide freeing in their respective grooves)
  • rotor housings (no metal flaking or gouges - "inside" surface should be free or surface damage)
  • side/center housings (same as rotor housings, but pay careful attention to water o-ring grooves) (This is the important one, as you're pretty sure you got a coolant seal leak.)
This leaves the follow parts that NEED to be replaced:
  • corner seal rubber plugs (x12)
  • water o-rings (inner x4, outer x4)
  • oil control o-rings (inner x4, outer x4)
  • front oil cover o-ring
  • front oil cover o-ring (white plastic) retaining ring
  • oil filter pedestal o-ring (x2, if needed)
  • dowel pin o-rings (x8)
  • tension bolt "stat-o-seal" washers (x19) [I think it was 19 total?]
  • front main oil seal (if needed)
  • rear mail oil seal (if needed)
  • rear stationary gear o-ring (if needed)
  • lower intake manifold gasket
  • upper intake manifold gasket
  • miscellaneous paper gaskets on turbos (if needed)
This actually ends up costing within $500...
Really costs 3 times as much a piston engine.......read a little before saying something like that.
Old 11-01-2004, 10:16 PM
Scoped_GST Scoped_GST is offline
Send a message via AIM to Scoped_GST
1G DSM if you wanna go that low and still have a 11-12 sec street car. Talon Tsi AWD, Eclipse GSX, etc. 1G DSM's might not look that great compared to the 2G's, but dont have as many issues as the 2G's. Remember...6-bolt is better if you want those times. 2G's and later 1G's have 7-bolt. Anyhow, good luck choosing a car, but 11-12 second reliable, cheap, and good looking cars are very hard to find for even 8K of investment. Good luck!
Old 11-01-2004, 10:21 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
I personally dont like the 1st gen DSM's sure they are cheap and get real fast fro real cheap, but to me they are pretty ugly, not real ugly but nany cars that arent much more look WAY better IMO, like the 2nd gens, the 5th/6th gen civic, the 2nd/3rd gen integras, preludes lok pretty good but I dont like the dash in the 92+.
I KNOW you can get a GSR into the 12's with a turbo, but not on the stock internals, the engine cant handle enough boost stock to hit 12's. Id say high 13's would be attainable on a stock engine with bolt ons and a turbo, maybe low 13's if its tuned GOOD and the boost is on the upper end of the "safe" range.
but GSR's arent cheap, can get good deals sometimes, especially on east coast.
also, why 96+ thats when they went OBD2, I would stay with the 94-95 GSR or the pre 92-95 ludes so you dont have to mess with it, I have never actually read a good reason why, bit its mentioned alot that OBD2 is just more of a pain when modding/tuning, the computer is more strict about what it will let you do or something like that. not 100% on that though
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
