Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-01-2004, 06:06 PM
87cutlass 87cutlass is offline
Send a message via Yahoo to 87cutlass
Unhappy 94 cutlass ciera 3100 v-6
Here is the deal I just bought this car and the miles on it is 98000 the car was not driven for about a year. Everything works the only problem is that the car has a weak take off when you try to do a fast take off it want to bog down only when taking of from a stand still once it is rolling it works fine. The car starts right up all the time and does not turn off while driving. The check engine light does not come on. I got a 93 lumina that has the 3.1 v-6 that makes the front tires burn some rubber so why can't this one do that.
Old 01-06-2005, 08:11 AM
Sconic Sconic is offline
Re: 94 cutlass ciera 3100 v-6
try replacing your fuel filter. It may be a little clogged.
the lumina and the cutlass probably have different trannys. I have a 94 supreme with the 3100 and my friend has a lumina with one and i can get rubber with my 4 speed and he cant with his 3 speed.
Old 01-06-2005, 08:33 AM
Thanks For the info.
As far as both cars are concerned they both have the 4 speed
I will replace the fuel filter I did not do it because it looks like they just replaced it.
Old 01-06-2005, 08:46 AM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
I would start with a tune up - replace fuel filter, plugs, clean injectors, etc.
Old 01-13-2005, 03:31 PM
I have changed the Plug wires air and fuel filter and there was no difference
Next is to clean the fuel injectors.
will keep you posted
Old 01-28-2006, 09:03 AM
Thumbs up Re: 94 cutlass ciera 3100 v-6
Finaly the problem has been solved it was the map sensor. I just took it off and cleaned it. it had alot of what I would call lint on the sensor. It is running like a champ now.
Old 01-31-2006, 09:47 AM
demo_deven's Avatar
demo_deven demo_deven is offline
Send a message via MSN to demo_deven
Good to hear
