Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-01-2004, 04:33 PM
crabby760 crabby760 is offline
chipped ecu vs stock
i have a 97 civic ex with the stock d16y8 motor i have intake/header/exhaust rite now i just got a p28 chipped mugen ecu vtec 5800 rpm redline 9,000 and the skunk 2 adapter for obd2 to obd1 would it be best to run the stock ecu or should u run the chipped one? someone let me know
IS IT WORTH IT WILL IT EVEN MAKE ANY DIFFERENCE?
Old 11-02-2004, 09:05 AM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
From what I heard, those chips suck. I would say convert to OBI just use a stock ECU. One of the main benefits of OBI is that you no longer have to worry about the ECU resetting your mods.
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
Old 11-02-2004, 04:01 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: chipped ecu vs stock
ECU chips are a complete waste of time and money period! Unless you have the maps programed buy a programer on a dyno with a wideband O2 sensor. Otherwise they are complete crap and can even cause damage to your motor.
Old 11-02-2004, 05:26 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah it can cause damage but it depends on the company who makes it, i mean a generic company chip sucks but if it is a true mugen chip then it should be good. jsut run premium gas and just put it in a see if it makes power
Team Lonely Drivers
Old 11-02-2004, 06:13 PM
whtteg's Avatar
That is the wrong way to go about it and that is also completly wrong. Every motor even two motor that were built at the same plant on the same day by the same tech will respond differently to settings. Also everybody does not have the same exact amount of flow in and out of the engine as the engine used to program the chip. Also everybody does not live in the same area ( elevation) as the car that was used to progran the chip etc etc.
Bottom line ECU chips= waste of money, time and a big disapointment!
Now ECU tuning is well worth the money if you have more than just bolt-ons, but you have to get someone who is using a dyno, wideband O2 sensor and knows what they are doing. Also this is almost always require something like Hondata so that they don't have to keep burning chips and installing them after every adjustment to the settings they make.
Old 11-03-2004, 02:41 AM
no, you think about it, yeah it advances timing and add more fuel, but mugen isnt gonna make a program that blows up your engine. a program they make is a universal program that takes into account the different enviornments you will encounter. the chip is like a stock ecu chip, its universal meaning its not making maximum power but it is making alittle more power.
now a chip wont make max power, you will need a program like hondata to achieve maximum power but the chip will still give you a few horses just not as much as having it tuned with hondata or whatevers.
there is also a sensor in a stock ecu that measure elevation and adds fuel according.
and your point about every motor being different, do they make ecus specific to evey motor or are ecu's all the same and can be swapped to different motors. like i was saying, the chip doesnt make max power but it does increase it alittle
Team Lonely Drivers
Old 11-03-2004, 04:20 PM
whtteg's Avatar
I am sorry but you are just simply wrong. Any chip that is "universal" will not do anything for your car except bring the possibility for damage. Advancing the timing is a bunch of B.S. It will do nothing for you either, if you advance the timing, then the bottom end power will slightly increase (maybe 1hp, if that) but your top end power will suffer. If you really want to run more advanced timing then just get a timing light and advance the timing by adjusting the distributor. Also another thing about ECU chips that a lot of people don't realize is that they dump more fuel into the motor, now if the motor does not need the extra fuel then you are going to loose hp. Also how does a manufacture in this case from another country going to know how much extra fuel your particular motor is going to need? They aren't! You can loose a decent amount of hp and tq by adding a chip. The only way to do it is like I said before with a dyno, wideband O2 and a program that allows you to adjust the fuel and ignition maps. A little change can result in a decent amount of hp gain or loss. Call any reputable shop in your area that does dyno
tuning and ask to talk to the guy who does the actual tuning and remapping of ecus and ask him about a "universal" chip, see what he says.
Also " and your point about every motor being different, do they make ecus specific to evey motor or are ecu's all the same and can be swapped to different motors. like i was saying, the chip doesnt make max power but it does increase it alittle"
About this, they have a safe amount of variation so that nothing can be damaged, but then when you add an "universal" chip you will be blindly removing that "safe zone" if you will.
Old 11-03-2004, 04:26 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
whtteg is right on this one... you can't just throw a chip in and be ready to go like that
LS1 RX-7 Zoom Zoom
Old 11-03-2004, 05:02 PM
then how come my friends car made more power with a bullfrog chip he added ?
Team Lonely Drivers
Old 11-03-2004, 05:12 PM
whtteg's Avatar
Got some before and after dyno sheets you can post up?
Old 11-03-2004, 07:05 PM
nope all i know was the fastest he ever got that car to go was 17 flat, after he got the bullfrog chip he went 16.8. now dont tell me it was a fluke because he has done over 30 runs before and he did about 10 when he got the chip so the results were repeated and not a fluke.
i have deduced that since he went .2 sec faster he has made power somewhere in his powerband
Team Lonely Drivers
