Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-01-2004, 04:00 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Car shakes when floored
Any reason my entire car would shake around like crazy at wot? It's kind of shakey at cruising speeds, but not as bad as wot. I have a b16b swap and just put in some brand new half shafts about two months ago..
Old 11-01-2004, 05:15 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Car shakes when floored
Mount or 2 gone bad maybe? Maybe pop the hood, start it up, rev on the throttle cable and see if the engine shakes.
Old 11-01-2004, 06:42 PM
Ricochet's Avatar
Banned
I tried doing it in neutral and it wouldn't shake, but I'll try that too.
Old 11-02-2004, 05:18 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
what kind of mounts do you got ?
Team Lonely Drivers
Old 11-02-2004, 05:29 PM
Ricochet's Avatar
Banned
stock.. I know it's not the engine, because it shakes a little more with speed but when I floor it it makes it worse no matter how fast I'm going. I dropped into neutral while going at 65, rpms dropped to ~800, and it was still shaking. I'm thinking it's a wheel bearing or the axles I got are junk..
Old 11-03-2004, 02:32 AM
if you put in new axles and it started doing it after that, then its probably your axles especially since you say it doesnt do it when your not moving, only when your moving it does that even in neutral, i would say its your axles. r u sure you got the right axles ? which ones did you buy ?
Team Lonely Drivers
Old 11-03-2004, 11:26 AM
Ricochet's Avatar
Banned
I got abs-equipped Si axles, the only ones that would fit according to my friend who's shop I took it to.
Old 11-03-2004, 12:36 PM
what kind of car do you have ? do you have abs ?
Team Lonely Drivers
Old 11-03-2004, 03:38 PM
SwiftAddictions's Avatar
SwiftAddictions SwiftAddictions is offline
Send a message via AIM to SwiftAddictions Send a message via Yahoo to SwiftAddictions
were they crap axles? Or maybe the mechanic who worked on it messed them up. I would take it back to the shop a talk to him, friend or not.
Light-wheeled Vehicles Mechanic, United States Army
[email protected]
Old 11-03-2004, 03:53 PM
Ricochet's Avatar
Banned
I have a 2000 hatchback
Old 11-03-2004, 07:09 PM
yeah i would get under there and loook at everything, make sure the half shaft is on good and in the tranny all hte way, the axle is on the half shaft good and in all the way on both sides. make sure they are in the tranny al the way.
Team Lonely Drivers
Old 11-04-2004, 12:00 AM
civic drivers doublespeak!
[email protected]
Old 11-05-2004, 12:58 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
how are your balljoints?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
