Old 11-01-2004, 03:44 PM
gschretter gschretter is offline
Making my own intake tubes.
Does anybody know where I can buy some cheap 3 1/2 alum tubing?
I want to make my own intake system.
Also where can I buy the clamps and rubber hose to attach parts to it?
Thanks.
Old 11-01-2004, 04:06 PM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Making my own intake tubes.
Have you tried a Plumbing shop or a shop that Sells Electrical Equipment. I'm sure they'll have everything you'll need. I imagine you'll probably want to rent a pipe bender if you plan on bending 3 1/2 tubing.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 11-01-2004, 05:29 PM
skipr skipr is offline
Yea, you will need a hydralic bender, i'm not sure about plumbing pipe sizes, but electrical conduit comes in 1/2", 3/4", 1", 1 1/4", 1 1/2", 2", 2 1/2", 3" and 4". These sizes are for aluminum intermident conduit and are measured using the ID (inside diameter).Have u considered "ALFLEX" conduit? or sealtight conduit? No bender needed for these.
Old 11-01-2004, 07:16 PM
nineball481's Avatar
nineball481 nineball481 is offline
the problem with flex is that it wont be smooth inside. It will cause a lot of turbulence. as far as bending goes, you will need a mandril bender or an aluminum welder and prebent 90's. an 855 or other electrical bender will have too large of a radius for this application.
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 11-01-2004, 08:34 PM
Thanks.
I will try the plumbing supply company.
I was thinking of buying a bender but you are right it would have wrinks for the 90 degree bend.
I wish someone would sell the 90 degree piece that I need.
Of course if I was smart I would buy this one and be done:
Ebay Intake
Old 11-01-2004, 10:11 PM
That E-bay intake system looks like a short 30 degree tube and a longer radius 45 degree tube with the stock Mass air flow unit inbetween them, and what looks like blue rubber boots under the hose clamps. It says polished T-306 aluminum. I wonder if they are referring to the outside or inside of tubing. I have a freind that owns a machine shop, that specializes in pipe and tube bending/welding. To bad your not local, I would set you up.
Old 11-02-2004, 08:18 AM
I heard that.
That would rock if I had a place that could do it.
Around here they want to much money.
I guess I could make it out of really thin steel and then I can mig weld it.
Or I could get the alum welding kit for my lincoln....
Hmm you got me thinking here.
Old 11-02-2004, 09:26 AM
You have the lincoln "weldpack 155"? So do I, great little unit, I don't have the aluminum kit. Have you considered stainless steel? You can go to any muffler/exhaust shop and they have large hydralic ram benders. They should do it for a very cheap price (like $10) of coarse u would bring your own aluminum.I had them bend a 2" (schedule 80) seamless chro-moly tube (this was before my freind got his shop) and they charged $5.
Old 11-09-2004, 11:48 AM
kammouflage kammouflage is offline
Re: Thanks.
Ebay Intake
I bought that exact intake off ebay that you're showing. I would definately not hesitate buying that one... it's only 50 bucks plus ship and it will save you a ton of hassle on making your own.
Also, the tubing is bigger than 3.5 inches. i'm guessing 4 - 5 inches. Deffinately don't try to bypass the mass air flow sensor, from what i understand that will cause HUGE probs.
Old 11-09-2004, 03:58 PM
Limited5.9Cherokee Limited5.9Cherokee is offline
Banned
chuck, you are such a frickin laugh. all your mods are with lights. a lot of lights, long, white.....
sounds like rice to me.
j/k
Old 11-09-2004, 04:16 PM
chuck16's Avatar
I put those mods on my signature so that if anybody wants to know how to do it they can ask instead of cruising through all the threads.
2008 GMC ACADIA
I AM Canadian!!
