Old 11-01-2004, 02:53 PM
Army31u Army31u is offline
Banned
Send a message via AIM to Army31u
New 2 the MARO world...need help
I just got 99 v6 maro with 141k on it....the engine sounds good as new when i run it but i need a new cat converter, and i think my power steering fluid is leaking...can some one help me and tell me how much all this will cost.....And a mechanic out here said my crank shaft is worn and i might need it fixed then another one said it s my cat converter wich i also believe
Old 11-01-2004, 03:05 PM
SMOKEY818 SMOKEY818 is offline
Re: New 2 the MARO world...need help
About a arm and two legs.
89 Camaro with lt1/t56/headers,borla exhaust,ac delete, march pulleys, slp CAI,3.73 gears,msd ignition,port & polished heads, reprogrammed pc, free mods, hotchkis suspension,sub-frame conn & weight reduction.
Old 11-01-2004, 03:13 PM
Banned
i need serious help...no bs please
Old 11-01-2004, 03:18 PM
well if you need to find out how much the parts cost, you should call 411 and get autozones # it's not like we have a parts list here in our heads.
Old 11-01-2004, 05:05 PM
Dober89 Dober89 is offline
a catalytic converted installed would probably be a couple hundred dollars. If you want though you could have it replaced with a high flow cat that would increase the power a bit.
I dont understand how a mechanic could tell you that your crankshaft is worn without actually looking at it himself. Replacing that would be alot of work and cost alot also. If would always suggest getting a second opinion from another shop though to help you compare prices better and also make sure people arent trying to rip you off.
Old 11-01-2004, 07:30 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
well i had both the return hose, and pressure hose on my power steering replaced and the hoses only came too around fifty bucks, as for the cat if u dont have immisions were your at y not just remove it yourself then have someone weld a pipe there probably cost u twenty bucks
Old 11-01-2004, 08:16 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
all i can tell u is don't believe that crankshaft bs, that fag is lying to u, he would have to get under your car, raise then engine, take off the pan all to inspect your crank. i bet he didn't do any of those, i hate mechanics that lie to people to try and get more money...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 11-02-2004, 12:07 AM
Banned
he just listend to it with some tool, and told me he heard rattling and that was my cat converter so hes bullshitting me...and i dont have emission here so what can i do with the welding??? or should i just replace it all??? and are those 5$ chips for 20hp on ebay any good??? let me know
Old 11-02-2004, 12:11 AM
tardster tardster is offline
Th chip thing is a big maybe, some might work some wont work its your choice on that. I myself would remover the cat and have someone weld in a piece of pipe and that will free up afew horses for you.
Old 11-02-2004, 12:12 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Do you smell a rotten egg smell?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-02-2004, 03:52 AM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
yeah some mechanics not all will try and bs you to death. post like these make me thank god my best friend and gf are mechanics.
get 3 opinions at least before you do anything with your car. 2 licensed mechanics and here
Old 11-02-2004, 12:57 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
ok, the cat, costs a few hundred from the dealership, get an aftermarket bolt in replacement, its a helluva lot cheaper and can do the same job. if at all possible replace it yourself. you can buy small oxy/acetalyn (sp) torches and heat the pipes and hammer them apart. then slide in the new one, i suggest having very thick work gloves to use, you will need alot of elbow grease in addition to the torch to get the exhaust aprt. a set of jackstands or ramps are also advized.
the crap about the crank, is bullshit, you cannot hear crank noise with a mechanics stethescope, you can hear lots of things, rod knock, piston slap, yadda yadda, but if the crank was actually making enough noise to hear with the stethescope, you would have metal shavings in your oil pan, if the engine hadnt completely seized already. I was a chevy tech for a cumulative 2.5 years. and i have NEVER heard of a crankshaft wearing out, especially in a 1999 model car. i wouldnt take my car there anymore if i were you.
as far as the power steering, the cost of repair depends on where the leak is, and what all has to be done.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-10-2004, 11:48 AM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Re: New 2 the MARO world...need help
Well to answer you , the cat bein bad will cause backpressure and thats not good. SO if u can cut it out and put in a pipe,or a highflow cat.AS FOR THE RIPOFF GUY,don't give anything because if the car runs as good as u say u would be able to hear a rod knock if u had one.He just pulled out the scope to make u think he was on the up and up.Any body that works on a car for a living could hear a bottomend knock without that scope.He did that for show because u r a girl.
