Old 11-01-2004, 02:00 PM
Jeepen86 Jeepen86 is offline
Question to hot!
i have my MTX 902 2 channel amp powering 2 10 in alpine type r's, I have it wired series/parallel and for some reason its not powering them very well unless i have the gain up most of the way and the amp gets to hot to touch and it shuts off, i belive because of the heat, oh and i have 0 ga coming from the battery into a dist block that runs a 4 gauge wire to the amp. the amp accepts 0ga, could to small a wire be whats causen it to get to hot? help! =(
Old 11-01-2004, 02:05 PM
TFFantasy44 TFFantasy44 is offline
Re: to hot!
Re-check your wiring and see if you are running it at the specified impedence. Chances are, your impedence is lower than the amp can handle, and cause it to burn up.
1996 Cavalier 2.2
[size=-1]
Audio Set-up
--Currently have--
NINe.1 Amp
eD 15A.22 Sub
Alpine 9855 Headunit
Old 11-01-2004, 08:28 PM
mx6rrr's Avatar
mx6rrr mx6rrr is offline
Re: to hot!
Make sure you have tight connections, expecially the ground wire/s!
Keep the rubber side down
