Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 11-01-2004, 12:07 PM
yellowbottle yellowbottle is offline
Reseting Service Light
Can anyone tell me on how to reset the service indicator on a 2004 A4 1.8T
Old 11-01-2004, 02:32 PM
mechy1barry mechy1barry is offline
Re: Reseting Service Light
if your on longlife service intervals,can only be reset using special equipment-if on fixed interval servicing can be reset using buttons on dash-send email for data sheet.
Old 04-10-2006, 05:47 PM
ct_millar ct_millar is offline
i have a audi a4 1.9tdi 130bhp 2002,can you tell me how to reset the service indicator on this model.
Thanx
Old 04-11-2006, 12:51 AM
s4fanatic27's Avatar
s4fanatic27 s4fanatic27 is offline
You might give this a try
This works on newer model B5 A4s. If it doesn't work, you'll have to
get the dealer to do it.
- Switch ignition off.
- Press
trip recorder reset button below speedo on instrument cluster and at same
time switch ignition on.
The trip recorder display (odometer)
will read "service OIL".
- Release button.
- Pull clock
adjuster button (below tach) on instrument cluster and hold for approx. 2
seconds. This resets "service OIL" display.
Note: Depending on
the make of the instrument cluster, the display on the trip recorder will
either continue to read "service OIL" (Nippon Seiki) or change to "- - -"
(VDO).
- Press trip recorder reset button again to advance to
next type of service.
- Release button.
The trip recorder
display will read "service INSP".
- Pull clock adjuster button on
instrument cluster and hold for approx. 2 seconds. This resets "service
INSP" display.
Note: Depending on the make of the instrument
cluster, the display on the trip recorder will either continue to read
"service INSP" (Nippon Seiki) or change to "- - -" (VDO).
