Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-01-2004, 07:44 AM
danford1 danford1 is offline
4R70W shift kit advice needed
I just bought a used 97 Tbird with the 4.6L and a 4R70W trans. The
trans shifts "normal" but I like firm shifts for longer trans life.
I'm not talking tire screeching neck snapping shifts (like what I did
to my old AOD :-) just nice firm shifts instead of the slide into
gear shifts, it has now.
I saw many shift kits for this trans by different companies. I'd
like to know what you guys used and what you recommend.
I'd also like to know if you tried any of the electonic devices like
from Hypertech or Superchip that not only reprogram the trans but
reprogram the engine for more power or mileage.
Please, let me know your thoughts and recommendations.
Thanks.
Dan S.
Old 11-01-2004, 11:33 AM
Bluthunder Bluthunder is offline
Shift kits
I would recommend doing the J-Mod on your tranny. What's a j-mod? It is a modification developed by the designer of the trans. It is a 2.5 on a 5 point difficulty scale for a diy'r. Check out TCCoA on the web. That is the Thunderbird, Courger CLub of America. If you own a Bird it is a must stop and see for car info on there forums. They are a great help and have good tech articles to assist.
Good luck.
Old 11-02-2004, 11:55 AM
forcfed93's Avatar
forcfed93 forcfed93 is offline
Re: Shift kits
Good luck.
Yep, J-mod is the only way to go ...........
Michael Albee - Prez
Super Coupe Club of IOWA
http://www.sccoia.org
1990 XR7 Auto
1991 SC Auto
1993 SC Auto
1993 Mark VIII (a.k.a. "The Winter Beater")
Old 11-03-2004, 11:04 PM
MN121995bird MN121995bird is offline
Re: 4R70W shift kit advice needed
I heard that the J-mod does a number on the trans, but gives you AWESOME shifts.
1995 Thunderbird LX 4.6
Flowmaster Exhuast
Hypertech Chip
Converted Civic Tube Cold Air Intake
New stock MAF(maybe a larger one later)
*Soon to Come*
Mustang GT TC
Lincoln Mark VIII Drive-shaft
PI Heads and 96+ Intake Manifold
The Plunderterd, stinkin up the whole place.
Old 11-04-2004, 02:23 AM
forcfed93's Avatar
Re: Re: 4R70W shift kit advice needed
It really doesnt hurt the tranny if the tranny is in good shape. The problems come when you j-mod a tranny that has tons of miles on it or one that has had a rough life. J-mod-ing just opens some passageways to allow more fluid to pass and changes some of the valving to make things happen more quickly.
If the tranny has worn or broken clutch plates or overheated springs inside, it can cause these parts to fail. Thats why the suggest that you go through the tranny completely if you are going to J-mod it!!!!
1990 XR7 Auto
1991 SC Auto
1993 SC Auto
