Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 02-21-2002, 04:50 PM
TIDEFAN TIDEFAN is offline
Unhappy Reprogram keyless remote control
Help !! I need instructions on how to reprogram my remote. I have one of the orignal remotes and it still works . I have bought one from a friend of mine and don't know how to program it . I found information to program a 1994-1996 . the only problem is I own a 1993 . thanks.......
Old 02-21-2002, 08:21 PM
jpalm jpalm is offline
Talking
Your lucky day, I happen to have them handy. I bought one off ebay awhile back that came with the instructions. Here you go:
While sitting in the vehicle:
1. Open the trunk
2. Close and lock all doors
3. Insert and remove the key from the ignition six times within 10 seconds
4. Manually unlock and lock driver's door once to enable "setting" mode
5. Push lock button on the new remote controller once, just long enought to hear it beep (BTW, mine didn't beep! Don't worry!), within 5 seconds of completing step 4
6. If additional remotes are needed (up to 3), repeat steps 4 and 5 for each additional remote immediately after programming the first remote (note: a total of four (4) remotes can be programmed to funtion on the same vehicle)
For addtional information please refer to page BF-38 of the 1993 and 1994 J30 Service Manuals
:flash: Jeff
Old 07-31-2002, 08:36 PM
n3w813 n3w813 is offline
j30/i30 remote
Was wondering if these are the same keys. The picture the manual shows of the j30 keyless entry remote looks the same as the i30. Anyone know if they are the same?
Thanks
Old 03-13-2003, 01:56 PM
malcolm malcolm is offline
I have seen a few nissan remotes and they just apair to have different pics on the buttons.I dont see why you carnt just set them for what you want.
Old 06-10-2003, 07:49 AM
zfhtang zfhtang is offline
I have a alpine sec-150r, but the remote control does not work . would anybody can help me to reprogram the remote control.
thanks
Old 09-06-2003, 08:22 PM
madnance madnance is offline
Talking
Jpalm, thank you thank you thank you. Oh, did I say thank you??? THe programing sequence worked great. It scared me when the horn started beeping to let me know it was programmed!
Old 11-15-2003, 02:59 AM
mask0425 mask0425 is offline
Re: Reprogram keyless remote control
What did you do to stop the horn?
I have not been able to program both remotes--just one at a time. Obviously, when I repeat the steps, the first one loses the code. Any suggestions?
Old 07-08-2004, 05:18 AM
JimZone JimZone is offline
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock knob.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Old 07-10-2004, 01:23 PM
DesiJ30 DesiJ30 is offline
Hi JimZone,
I have a 94 J30 but I can't seem to program my remote following the insturctions you posted. In the second step you said
Code:
When I look at the ignition socket. The positions are as follows Lock--->ACC ----> ON ----> Start
So, I opened my trunk, sat in the car, closed and locked all doors. Then insterted the key, put it in ACC position and removed it (seven times within ten seconds). But I didn't see any hazard light. Regardless, I put the key into ACC postion and press the lock button on remote. But it did not work for me.
Am I doing something wrong. For step 2 am I supposed to put the key into some postion other than the ACC?? Any help will be appreciated. Thanks in advance. =DesiJ30=
Old 09-01-2004, 02:05 AM
spotco2 spotco2 is offline
Banned
Here is a link to the correct procedure
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7914395274
