Old 10-31-2004, 11:21 PM
devildust devildust is offline
94' engine shaking
Ok, here is the problem. I start my car(94 LeSabre) engine starts shaking slightly. I press the brake and put it in drive shaking is horrible. Start driving, berely drive, loss of power and a lot of shaking. What could be wrong???
Thanks
Old 11-01-2004, 03:00 AM
avatar307's Avatar
avatar307 avatar307 is offline
Re: 94' engine shaking
Did you check the transmission fluid?
"Sleeping is the only thing keeping me from killing all the stupid people on this planet."
"Of one that loved not wisely but too well;" (Othello, Act 5, Scene 2, Line 344)
Old 11-04-2004, 06:19 PM
Bassasasin Bassasasin is offline
Re: 94' engine shaking SPARK PLUG?
Thanks
It sounds like spark plugs or.. your plugwire wiring to your ignition coils have been moved switched.. I had same troubles after moving them and putting them back wrong....otherwise.. one of the coilpacks has failed.. get another from a junk yard..preferably crashed vehicle.. they usually were running well when they crashed.. heh.
Dan
Old 11-05-2004, 06:57 PM
auto trainy auto trainy is offline
Start by replacing the wires and if still ng then try coil packs,one thing at a time.
Old 11-08-2004, 07:38 PM
stank23 stank23 is offline
Send a message via AIM to stank23
i had the same problem when i used bosch platinum spark plugs.my mechanic recommended i got buy ac delco plugs.so i did and it fixed it right up.apparently these things are pick about their plugs
Old 11-08-2004, 08:49 PM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Actually, I would check the coil packs first, because you don't need new one to test them.
1986 LeSabre Limited L67 sleeper
Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast,
Old 11-11-2004, 11:23 PM
Fuel filter was dirty. Thanks all
