Old 10-31-2004, 11:02 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Question seat conversion
will my stock seat mounting brackets fit on another aftermarket seat with slight modification such as drilling of holes
Old 10-31-2004, 11:48 PM
travagliante's Avatar
travagliante travagliante is offline
Re: seat conversion
depends on which brand/model of seat it is. Most aftermarkets have brackets which allow them to bolt onto the stock rails
Old 11-01-2004, 04:30 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: seat conversion
Alot of seats come with a bracket application that'll make the seat fit the car. But alot of times, I've heard, they don't get you the right ones so be careful.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 06-08-2005, 06:50 PM
TeameXcessive TeameXcessive is offline
Re: seat conversion
That's what i'm trying to fine out. the seat that i got is way off. I can put the stock bracket into the seat, but i will have to drill a hole to make it fit.
Old 06-08-2005, 08:19 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: seat conversion
on 88-89 seat rails, its really easy because the rails bolt to the bottom of the seat. on 90-91 its harder because only one rail bolts to the bottom, the other bolts to the side.
for my 88 hatch, i used the stock rails, and then made brackets to mount it up to the seat
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-09-2005, 06:26 AM
civicunrest's Avatar
civicunrest civicunrest is offline
my racing seats that are in my car were the same way and i had to modify mine to fit.for a complete breakdown go to www.civic4g.com and do a search inquiry on civicunrest as the aurthor and scoll down to racing harness question and read what i wrote.i hope that helps and good luck
