Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-31-2004, 11:56 PM
SSZero's Avatar
SSZero SSZero is offline
At what RPM should I launch my stock GST at the track?
Hey everyone. I've taken my car to the track a few times to see how I'd run. The best time I've gotten so far with my auto GST (stock) is 16.3... I don't know about you guys, but I think that's pathetic, and I know I can do better... I need to know at what RPM it would be the best to launch at, and I'd like to know when the best time to shift would be. My buddies have told me to blow off the turbo right before redline and then shift, but I've only tried shifting while blowing off so far. I need to know what the best way to shift would be so that I get my car within the 15 or possibly high 14 second range... Help me out... Thanx...
'96 Green Eclipse GS-T
Stock for now...
Old 11-01-2004, 02:33 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: At what RPM should I launch my stock GST at the track?
I have no idea what your buddies are talking about. Especially since its an auto. The turbo shouldnt "blow off" at all until you finish your run.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-01-2004, 02:35 AM
SSZero's Avatar
By blow off, I mean take my foot off the accelerator, then putting my foot back down on it... O_o lol
Stock for now...
Old 11-01-2004, 02:37 AM
AF - Advisor
I dont think that will make the car any faster
Kevin Jewer
Old 11-01-2004, 02:47 AM
SSZero's Avatar
I'm not sure about that... Won't letting the turbo blow off relieve, then quickly reinsert pressure? Thus, making me accelerate a little better? Don't forget, manual cars do that already since you have to let go of the accelerator to switch gears. If I'm switching gears in an auto, I do believe I have to do the same, otherwise I think I might blow the turbo or my engine...
Stock for now...
Old 11-01-2004, 02:48 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
another question? how the hell are you launching it at varied RPM's?
PLEASE tell me you are not revving it and slamming it down into drive.
personally I would put it in 1, hold the brake with left foot, or instep of left foot if pedals are close enough, and when the staging lights are lit, floor it with the right foot or outside of right if doing option 2. by the time the 3 yellows went by it should be stalled a pretty good RPM, and then when the last yellow has lit slip foot over all the way to the gas or release the brake and go, then right before redline push the stick into 2, then right before redline shift up to D or however yours are numbered/lettered. none of that letting off the gas and flooring it crap, alls it does is take fractions of a second away from the time you are actually accelerating and letting out the boost only to make it have to build again (which wouldnt take long sicne the turbo stays spinning pretty damn fast but still wastes precious time) Id try it not shifting it either to see if it makes a difference, ive been in cars where it automatically shifts right at redline, my mustang shifted pretty early, and some cars ive been in upshift faster by themselves than when the driver intervenes and does it them selves, my car was one of them but I still think it was faster my way cuz I didnt fall so low in the curve even though it took a bit longer to shift
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 11-01-2004, 03:14 AM
george536's Avatar
george536 george536 is offline
Re: Re: At what RPM should I launch my stock GST at the track?
its better to hold boost, then let it go.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 11-01-2004, 03:35 AM
SSZero's Avatar
Neutral drop, NEVER!!! I know how bad it is to do that... I just leave in low, rev to about 3000 rpms (right when the turbo spools), then let go of the gas and go... I'm going to try without shifting and without letting off the gas while I shift. It might help... But hey, with a stock GST, what's the best time that I could get?
Stock for now...
Old 11-01-2004, 03:43 AM
george536's Avatar
let go of the gas? i dont think that will help. lol
-1990 Eclipse GSX
Old 11-01-2004, 04:01 AM
SSZero's Avatar
Oops, I meant let go of the brake...
Stock for now...
Old 11-01-2004, 09:26 AM
94tegRS's Avatar
it does that on a manual, not for the sake of "being quicker" when you hit the next gera, its so when you close the throttle plate theirs not 15 lbs+ of boost pushing against it and building tons of boost in the piping/IC cuz nowhere to go, since engines not breathing it all in.
and when you let off and floor it again, you feel it jump, but thats cuz you let off so now your not accelerating and when you stomp on it your high in the powerband where you got most your power and it pulls hard right there. and is 3k the highest stall speed you can get outta your car?
current
history:
Old 11-01-2004, 10:42 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
you want as much pressure goin thru the motor at all times without getting knock!
i dont blame you kevin for not posting in this thread after this post
Old 11-01-2004, 11:32 AM
joemathews's Avatar
joemathews joemathews is offline
No.
Think about it, bro...combustion relies on the amount of intake air to be powerful. That's why turbochargers make our cars so much faster. Would closing off the supply of intake air when you don't drive a manual car and need to change gears really help INCREASE performance?
Launch at like 3k rpm, hold the pedal to the floor, and break into the 15s .
1996 Eagle Talon
Old 11-01-2004, 02:17 PM
SSZero's Avatar
Thanx man... I really needed that... lol Now I'm gonna shut my friends up (they're Honda lovers bent on making me get rid of my GST. And they don't think I'll hit 14 seconds with this car. In time, though, they'll see...
Stock for now...
Old 11-01-2004, 03:26 PM
SSZero's Avatar
OH YEAH! I also forgot to ask. At around what RPM is the best time for me to shift in my auto? I'm thinking between 6500 and 7000 (redline)... I know I can't shift at 7000 since I have that delay, being that it's an auto, so when should I shift?
Stock for now...
