Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-31-2004, 09:51 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
transmission problem
ok the cars are a 93 eclipse 1.8 and a 91 talon Tsi AWD.
im looking at buying the talon but right now it doesnt come out of second gear. the linkage moves on the trans so i think its an internal problem.
what im wondering is whether i can put the trans from the 1.8 in the talon. i know that the gear ratio is higher in the 1.8 and that i'll need to move the tranfer case to the 1.8 trans. what other differences are there? does it matter which axles i use?
off topic question: does the 91 and earlier talons have a crank operated sunroof instead of a pop up or is it supposed to be the same as the later ones?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-31-2004, 10:16 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: transmission problem
i believe you can't since the 1.8 is FWD and the TSi is AWD.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-31-2004, 10:24 PM
that just means i need to bolt the transfer case onto the bottom of the 1.8 trans. it just hangs off the bottom
-1stGenRocks-
Old 10-31-2004, 10:58 PM
kjewer1 kjewer1 is offline
AF - Advisor
There will be nowhere to bolt the tcase on unless it is an AWD tranny.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-01-2004, 06:23 PM
ok i thought that it just was blocked off on the fwd trans. how much do you think the parts to do a full rebuild on the awd trans will cost. im going to call the stealership tommorow but does anybody have a rough estimate? i m thinking syncros, bearings, shift forks, etc.
edit>> nevermind i found a used trans and tcase for 275 on dsmtrader.
-1stGenRocks-
Old 11-19-2004, 01:44 PM
riff22 riff22 is offline
i paid 800 to get a clutch and 2 gear sincros put in
Old 11-19-2004, 07:35 PM
what was the cost of just the parts? im a mechanic so im gonna do the work myself and i can get parts at wholesale price (usually about half of retail)
-1stGenRocks-
Old 11-20-2004, 06:54 AM
97 black gsx 97 black gsx is offline
Send a message via AIM to 97 black gsx
I rebulit a 97 awd trans. i busted the shift fork in second gear it kind of sounds like the same problem i took my tranmission apart and found what was broken and order new parts from WWW.teamrip.com they can help you out to but the 1.8 trans will not work.
drive it like u stole it
boost it
