Old 10-31-2004, 08:45 PM
crzywvguy crzywvguy is offline
Parking Break Warning Light Flashing???
I have a 89 2500....was going to switch the gauges out from a 90 1500...but after i put the dash in i took it out and replaced the original but ever since then the break light has been flashing constantly...anybody know what would cause it.
Old 11-01-2004, 07:06 AM
Thunderbolt Thunderbolt is offline
A flashing brake light on that year truck indicates a problem with the anti lock brakes. The code will need to be read in order to know what is causing it and I am not sure if there is a way pull brake codes without a scanner.
Old 11-08-2004, 08:12 PM
dbcvn69 dbcvn69 is offline
have same problem. mine started after having short in ecm power wire.found this site to be very helpful as it explains flash codes.
hope it helps.
http://www.autosite.com/garage/encyclop/ency14l.asp
Old 11-09-2004, 08:38 AM
Fireplug Fireplug is offline
Re: Parking Break Warning Light Flashing???
sounds to me like there is a pinched wire or loose wire on the back of the dash gauge cluster
Old 11-17-2004, 10:36 PM
landman landman is offline
I had the same problem with my truck after taking out th gauge cluster and replacing it. I didn't disconect the battery when doing and I think it puts a fault in the computer. I then disconected the battery for a few minutes and the connected it back, everything seems fine and no more blinking. Give that a try.
Old 11-20-2004, 05:35 AM
Cam7 Cam7 is offline
Try jumping terminals A&H on your ALDL, that will give you codes for your ABS if that is the problem.
