Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 10-31-2004, 08:10 PM
djbusch djbusch is offline
88 Bronco ii rough run intermittant and rich
It's one year later and the same problem came up again. My code reader didn't indicate anything wrong so I went to a reliame repair facility. They came up with a code 41 and replaced the o2 sensor. It's running well except for a little stumble when cold just after starting out.
That could be due to the vacuum to the air cleaner being plugged for a leak at the bi-metal device.
Old 11-13-2004, 08:30 PM
lm18 lm18 is offline
Re: 88 Bronco ii rough run intermittant and rich
i had a simmilar problem with my 88 a few years ago, the shop replaced the sensor and works fine for a few days and then the problem start again and again, after a lot days without success, i went to another shop and they replaced the gas regulator, problem solved until now
