Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-31-2004, 06:42 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Z31 n/a with boost...
ok guys...i was doing some hard core thinking and seaching for a second car that i can use as a daily driver. well...i came across this 86 2 seater 300zx but it needs some engine work but the body is pretty solid besides alot of chipped paint on the bumpers. no rust, just some mississippi sand. the car came from mississippi. anyways...im not looking to make this any sort of a huge project or anything anytime soon. just want to get a good runner.
but i was thinking this....the n/a z31 is only running a 9:1 compression ratio. that is not a bad compression ratio when it comes to forced induction. now my question is, wouldnt the engine be able to handle the stock 6psi that the turbo model has. and this would give a pretty decent jolt in power. what do you guys think??? not a plan or project,....just wandering.
ZedEx Crew Member #4
Old 10-31-2004, 08:37 PM
JCCR JCCR is offline
Re: Z31 n/a with boost...
i heard that you can boost up a z31 but its to expensive to were you'll end up spending more than what the car is worth.
Old 11-01-2004, 07:33 PM
higherlevel higherlevel is offline
I have a 86 na and it does feel like it could use a boost but the compression on a turbo of that year is lower. If it was around $1000 give or take they would have a customer.
RIGHT NOW:
k&n filter
plugs wires hoses
2.5'' header back exhaust
tokico springs, struts
stillen drilled rotors
11oz flywheel
ACT organic clutch
TO COME:
electric fan conversion
stillen headers
pathfinder manifold, dist.
ecu upgrade
Past Z Car Crew
Old 11-01-2004, 10:51 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
You'd be fine. I wouldn't go much higher just to be sure, but you could probably pull it off.
I know you're not looking for a project or anything...hope this doesn't change your mind...
http://z31.com/board/read.php3?id=608047&srf=nein&sm=
Guy I've been talking to for a little while...helped me plan for my project. Cool guy. His car sounds like a piece of work, too. All he did was bore it out to 3.3L, do some head work, put a turbo on it running stock boost and install a WRX I/C. 221horse, 291tq at the wheels. He'd give you stock Z32TT guys a GOOD run for you money right now...and if he upped the boost to ~12-14 psi...hold on for dear life...
His pics didn't work for me right now, so try again later...has some cool pics of his intercooler and intake work...kinda clever the way he worked it all in...it's very simple...
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 11-01-2004, 11:40 PM
Z Cars Fanatic
thanks LLTZ...i thought it might work if you ran pretty low boost beings the compression is only 9:1. i dont plan on doing it. just plan on getting mine running.
hehe...I OWN 2 Z's.
Old 11-04-2004, 12:41 AM
Zgringo Zgringo is offline
K3 I just happen to have a complete turbo set-up for a Z31, with 'bout 35,000 miles on it. All I need to do is find it in all my stuff.
Old 11-04-2004, 12:44 AM
Z Cars Fanatic
damn you people... you all are gonna make me file for bankruptcy.
thanks zgringo....but i kinda got my hands fileld right now. if you still got anything for me when i get done with my z32. i might have a closer look see.
Old 11-04-2004, 12:48 AM
No problem. Their sitting in my shop some place and not going anyplace.
Old 11-04-2004, 02:16 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
hey uh... mr. zgringo.... you wouldn't want to uh.. hook me up would you?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
