Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 10-31-2004, 06:41 PM
west nile west nile is offline
Skunk 2 Camber Kit Install
Just installed the kit today, a little bit more difficult than I thought it would be, but once you figure everything out not that tought. Things to remember:
1. The bolts holding the A frame in place at top are in the engine bay, Me being impatient and wanting to hook it up fast started torquing down on the end nuts in the wheel well, those are not the ones you loosen!
2. Need either a ball joint seperator w/sledge hammer, or just sledge hammer. The ball joint seperator worked fine, just put it in between the oem A frame and the spindle arm, and just pound the hell out of it which pryes them apart.
Other than that pretty straight forward just put everything back together and adjust, just wanted to help someone out who is searching threads trying to figure it out before hand, like I should have done, oh well
peace
