Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-31-2004, 05:54 PM
SSZero's Avatar
SSZero SSZero is offline
My first upgrade to a stock GST should be...
Hey guys. I've tried to research this as much as I can, but it seems as though I'm left in a sort of loop when trying to consider what my first upgrade to my GST should be. The two main choices I have is to either get a boost controller or an upgraded ECU chip since my car's automatic. Now, I was leaning more towards the ECU chip, but I need help to figure out what to do FIRST. As in, MY FIRST UPGRADE. Also, I had the option of making my car straight pipe, but for now, I probably won't be able to since I'm having troubles with the mechanics actually wanting to do the procedure. I just need some advice on what to start off with... Thanx...
'96 Green Eclipse GS-T
Stock for now...
Old 10-31-2004, 06:22 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: My first upgrade to a stock GST should be...
i think that you should go with the boost controller you really only need to upgrade the ecu once you have a great amount of power and you cant do. someone told me the the t25 can do up to 16 pounds of boost but i would make sure dont want to ruin your turbo unless you have another or some money
Old 10-31-2004, 06:30 PM
george536's Avatar
george536 george536 is offline
http://www.dsmtuners.com/tuning-guid...tage1power.php
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-31-2004, 10:03 PM
kjewer1 kjewer1 is offline
AF - Advisor
ECU chip will require a 95 EPROM ECU. Which are hard to come by theses days. But I highly recomend DSMlink when you do go this route. And I wouldnt hesitate to recomend DSMlink to people still on the stock turbo by the way
That being said, first mods should be filter and exhaust. With a K&N fipk and buschur 2.5" turbo back (with cat) I ran 14.3 on pump, no other mods. Then I added all the other usual stuff and went a whopping 14.2. Race gas dropped it to 13.7, but you see my point. Intake and exhaust are the heavy hitters, I would certainly start with those. Then proceed with the usual upgrade paths.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-31-2004, 10:33 PM
SSZero's Avatar
Thanks a lot for that website, it'll really help me out. By the way guys, don't forget my car's automatic. I'm not gonna get it down as fast as manuals...
Stock for now...
Old 11-01-2004, 01:30 AM
AF - Advisor
auto DSMs are in the 9s these days But until you put a little money into them (cost of 1 ACT 2600) the 5 spds do have a decent advantage... I was seriously considering swapping my car to auto to save money in the long run but a fully built auto is nearly 3 grand. Even worse I would have to find the transfer case and 4 bolt rear from an auto since the ratios are different, and I'm way to lazy for that. At any rate, the order of modding should be the same in teh beginning.
Kevin Jewer
Old 11-01-2004, 07:35 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Well if you dont have a filter yet, that you prob be the first. Also make sure you get yourself a boost gauge, if you dont already have one. Check the site that George posted, its a very good guide.
Good Luck!
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
Old 11-01-2004, 08:15 AM
EclipsNgirl EclipsNgirl is offline
Send a message via AIM to EclipsNgirl Send a message via Yahoo to EclipsNgirl
Don't forget to do all the free mods either
98 Eclipse gst-race ready
95 Eclipse gst-stock
92 Eclipse GST-parts car
91 Talon tsi RWD
87 Conquest-our new baby
Old 11-01-2004, 01:19 PM
SSZero's Avatar
Just to make sure, which free mods are you talking about? The only one I know of is the intercooler one...
Stock for now...
Old 11-01-2004, 01:54 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
www.vfaq.com
Please read the "Read this first" stickies at the top of the main forum.
Kris
2012 Genesis Coupe 2.0t
Old 11-02-2004, 07:36 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Re: My first upgrade to a stock GST should be...
stock turbo you say ....
do u mean DSM link right off the ball ,first thing...
or after intake ,exhaust, boost controller ,boost gauge , and bov?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-02-2004, 09:19 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Re: Re: My first upgrade to a stock GST should be...
I don't think it really matters, but you will need the basic bolt-ons that you've listed to fully utilize the stock turbo untuned. Then you can go back with dsmlink and get a couple more ponies out of it before having to upgrade turbos! I'm still on the t25 (very soon to have a 14b) and dsmlink will be ordered the day after thanksgiving! I have no doubt that you could even get more power out of the t25 with dsmlink with some good tuning and race gas.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 11-02-2004, 11:37 PM
AF - Advisor
I Think the sooner you get DSMlink the better. But you will get more performance gain from the other parts than the DSMlink. But there is more to DSMlink than just increasing performance. There are some bigtime "convience mods." But for most poeple adding power is more important so they put it off, and thats fine. But I Would definitely say that you will gain more power on the stock turbo with tuning than without. When I ran the 13.7 at 99 on the T25 it was pig pig rich. If I had fuel tuning it would have run much better. Etc.
Kevin Jewer
Old 11-03-2004, 02:14 PM
SSZero's Avatar
Hmmmm... DSMLink 95 EPROM ECU... I'll check it out...
Stock for now...
Old 11-03-2004, 06:14 PM
Partizan's Avatar
Partizan Partizan is offline
Shift kit maybe?
