Old 10-31-2004, 05:51 PM
DukeMan's Avatar
DukeMan DukeMan is offline
Question Can it be done?
Simple question, I have a bunch of parts with quite extreme convex and concave curves but my question is concerning this one particular part, the front fender:
http://images2.fotopic.net/?iid=y57m...ze=1&nostamp=1
As you can see in the first pic (hopefully), the temporary template I made has quite a lot of wrinkles, now I´ve read about the SMS decals here and came to the conclusion that they are simply the best ones around. But, can they form into that kind of extreme shape?
Any thoughts, suggestions, I´m going to try it sooner or later but I´d really like to hear some comments from the very skilled people on this site, : )
Regards, Fredrik
Old 10-31-2004, 07:19 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
that should work out pretty easy, lots of people have used cf on bike fenders. all you got to do is use a setting slolution and let that do the work for you.
you can always cut that into 3 pieces to make it easier.
Old 11-01-2004, 01:39 AM
_WIDE_LOAD_'s Avatar
_WIDE_LOAD_ _WIDE_LOAD_ is offline
Send a message via MSN to _WIDE_LOAD_
Re: Can it be done?
im with JT, cut the decal into 3 or more to make appliction easier.
laters, WIDE
My name's Troy, use it if you like.
If you're a Buddist, you go to Tibet....If you're a speed freak you go to the Salt Flats
351 clevo....aussie muscle
Old 11-01-2004, 04:52 AM
Tikiman's Avatar
Tikiman Tikiman is offline
Re: Can it be done?
Yeah, i would also cut it into 3 peices. I made a bike which came with a CF decal for the front fender and that was in 3 peices already, so i guess that is the best way.
Old 11-01-2004, 04:58 AM
Uninen Uninen is offline
Yup, I agree. Cut it in 3. First I'd lay the two side pieces and the top piece last, so the edges would be less visible. A hairdryer is also very handy when applying on a really curvy surface. I haven't applied on a bike fender myself, but on an Evo scoop. Worked great!!
Old 11-01-2004, 07:01 AM
DukeMan's Avatar
Thumbs up
Thanks everybody, think I´ll buy two SMS sheets and try both methods. But here is a even more tricky little piece, I really doubt that yiu can lay a decal onto this without wrinkles:
http://images3.fotopic.net/?iid=y58y...ze=1&nostamp=1
Could you possibly try and cut a circle and then cut to the center of it and then try to lay it down? Or is the SMS decal so f-cking great that it can handle this shape?
Regards; Fredrik
Old 11-02-2004, 12:07 PM
DukeMan's Avatar
Well, feeling kinda silly answering to my own reply, but anyway since I had a little scrappiece of SMS CF left, I decided to give it a shot:
http://files.automotiveforums.com/ga...sort=1&cat=502
It´s just a test, I did it mostly ´cus I wanted to "feel" how the decal would respond to the shape.
Regards, Fredrik
/Fredrik
Current Projects:
-´70 Camaro Z28 (Baldwin Motion hood wanted!!!)
-´32 Ford Roadster (on hold)
´69 Camaro thread
Old 11-02-2004, 02:21 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
Re: Can it be done?
I havent seen a shape that SMS decals wont cover without wrinkles if it is cut into pieces correctly and setting solution used.
