Old 10-31-2004, 02:43 AM
eXcelon eXcelon is offline
Question How do you add Daytime Running Lights ?
does anyone know how to add daytime running lights to a 2001-2004 Dodge Grand Caravan that doesnt have it ? is it a relay or module that i can just put in ? and does anyone know where it goes ? is it under the engine hood where the fuse box is or is it under the front drivers side foot panel ?
Old 10-31-2004, 08:16 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
If you have a 2004 , it's done thru software programming of the BCM.
On the other year models, verify if you have the turn signal module on the junction block that is under the dash on the driver's side. The module is about the size of a deck of cards. Replace the module with MOPAR DRL module # 04606139AB (Daytime Running Light Module -2001 thru 2004 Caravan/Town & Country)
The module costs anywhere from $60.00 to $78.00, only available from Dodge/Chrysler dealers.
Old 10-31-2004, 10:40 AM
Re: How do you add Daytime Running Lights ?
cool thanks. i got a 2002 Caravan so i guess ill have to double check.
Old 06-07-2006, 01:37 AM
Question Re: How do you add Daytime Running Lights ?
ok 2 years later and module in hand. i finially looked to see if i have the junction block i cant seem to find it. under the dash of drivers side would the block be on the right or left side and how far up would it be ? thank you for anyones help and time.
Old 06-07-2006, 06:21 AM
If you have the junction block, it would be to the left of the steering column.
Since I added the first reply, I looked at my son's '02 Dodge GC, and he DOESN'T have the block. His van is also done thru software programming.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
