Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-31-2004, 01:43 AM
crabby760 crabby760 is offline
installing camshafts QUESTION
aye i got a 98 civic ex with the stock d16y8 motor i have intake/header/exhaust i just bought a crower stage 2 camshaft and a skunk 2 camgear curious what steps have to be done in order to install a camshaft let me know thanks....
Old 10-31-2004, 01:28 PM
BullShifter's Avatar
Re: installing camshafts QUESTION
The job is pretty straight forward, I would rate it 2 on scale of 0-5 5 being the hardest. Proper torque is very important!
Here's a link for a 91 D16 head section from a factory repair manual, yours will be very close but I suggest the proper manual to get the proper torque spec's.
91 D16 - http://www.binghamtonlife.com/manual...alve_train.htm
Manuals - www.helminc.com or go to a honda dealer & ask if you can copy the pages needed.
To get the most of it a ported and polished head, instake & throttle body are very important. Valve springs are a good idea also. For the full benefit of a cam gear & other listed mods dyno tuning is the only way to go.
Old 10-31-2004, 04:22 PM
so far i have installed i/h/e
to be installed is
3 piece pulley kit UR
crower stage 3 camshaft
skunk 2 cam gear
then i wanna buy a vafc and get it dyno tuned
Old 11-01-2004, 11:06 AM
Eddiebx Eddiebx is offline
isntall is staright foward, tips:
make sure its at TDC BEFORE you remove the tming belt
and use plenty of assembly lube, =)
Old 11-02-2004, 05:15 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you said stage 2 in the first post and stage 3 in the second which one is it ? also you gotta install valve springs because of the extra lift it will cause binding with stock valves, unless otherwise noted
Team Lonely Drivers
Old 11-02-2004, 06:08 PM
even if i dont rev past 7k rpm?
Old 11-03-2004, 12:05 AM
yes, you should install the springs with any aftermarket cam in my opinion.
Old 11-03-2004, 03:24 AM
can anyone give me step by step installation instructions for installing a camshaft and cam gear on a d16y8 motor please... thanks
Old 11-03-2004, 06:45 PM
Re: Re: installing camshafts QUESTION
start by checking out the links I orginally posted. No offense but if you can not figure it out from there I would suggest pro. installation
Old 11-04-2004, 02:48 AM
i just need torque specs for the cam caps and whatever else holds it down...
and valve adjustment specs for intake and exhaust.... please thanks
its a d16y8 also
Old 11-04-2004, 04:32 AM
the sheet that comes with the cam might have valve adjustment specs on it.
if you get some kidn of manual for the car, haynes, chiltons, helms it will give instrutions on how to change a cam and torque specs
Team Lonely Drivers
Old 11-04-2004, 06:57 PM
nothing cam with the camshaft guys..... can someone find me valve adjustment specs for the d16y8 please and torque specs to bolt down the camshaft... thank u
Old 11-04-2004, 07:45 PM
GTR2b's Avatar
GTR2b GTR2b is offline
crabby,
you seriously need to get a service manual for your car BEFORE you take one bolt off that car! Read it cover to cover and it will outline in great detail everything you need to know. Most include pictures as well.
If you don't heed this advice, you will be right back on the forums asking why your engine doesn't start, or asking if bent valves are a "bad thing". The risk of damage to your new cam, valves, and other components is too great.
But, it's your car... do what you want but don't say you weren't warned.
Old 11-04-2004, 07:48 PM
doesnt someone on here know the specs i am asking for?
Old 11-04-2004, 08:56 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Please go to www.helminc.com and buy a manual. It will only take a couple of days to get it and it will tell you everything you ever wanted to know about your car. Please I urge you to buy one, they are invaluable.
